PXAMG (iSimple) install location in a 2005 G35x
Old Nov 18, 2009 | 01:19 AM
deepakhj's Avatar
Hey,
I finally got my iSimple gateway working in my G35x by disconnecting the satellite cable even though they say it works on their website.
The only problem I have right now is where do I install the box? I tried under the stereo unit but it doesn't seem like there is room. I don't see any other place to fit it in. Where did you install yours?
Any ideas would be appreciated.
Old Nov 20, 2009 | 01:34 PM
deepakhj's Avatar
Any help?
Old Nov 24, 2009 | 11:57 PM
jpne13's Avatar
mine fit right under the head unit right behind the asstray. i have a 05 coupe
Old Dec 2, 2009 | 06:03 PM
deepakhj's Avatar
Ended up pulling the carpet and stuffing it to the left of the passenger area so that I can pull it out in case a firmware update came out. Then ran the cable to the center console and through a hole in the cigarette lighter box.
Old Dec 3, 2009 | 09:49 AM
VandyZ's Avatar
Did you do the necessary updates to the firmware? IIRC, that will allow you to keep SAT functionality.
I somehow have mine mounted under the HU. I remember it was a pain.
How is your volume level with the iPod? I am still not satisfied with the amplification / gain level.
Old Dec 3, 2009 | 11:43 AM
deepakhj's Avatar
Yeah I updated to the latest firmware but SAT still didn't work. It would pause every 5 seconds.
The volume level is about 5 below what I'd usually have the Stereo at. I usually have the stereo at 23-25 now vs 18-20.
I think the convenience of being able to drop music on my iPhone on the go outweighs the volume levels.
Old Aug 22, 2013 | 09:55 PM
Jamal_G35x's Avatar
sorry to revive dead post but I installed mine today into my 05 g35x and it wont work. I have CD, RADIO, SSV, and DISP buttons on my radio. Everytime I hit the radio button it won't cycle to "SAT" mode? How did you get yours to work?
Old Aug 22, 2013 | 11:02 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
If the device simulates a CD changer, try tapping the CD button. Ones that simulate sat radios work via the radio button.
Old Aug 22, 2013 | 11:56 PM
Jamal_G35x's Avatar
I tried that and nothing happened it stayed in radio mode when I hit the cd button?
Old Aug 23, 2013 | 01:05 PM
That's a little odd. If you disconnect it, does it go to CD like normal?
Old Aug 23, 2013 | 01:36 PM
Jamal_G35x's Avatar
Ya it will go into cd mode when I press the load button but not when I press the cd button. The guy I brought it from had the same buttons as me and said that he acceded it through say mode when cycling the radio button
Old Oct 12, 2013 | 07:17 PM
mindbeats's Avatar
Where do I disconnect the sat cable from? I have an 06 g35x
Old Oct 12, 2013 | 11:38 PM
If the sat cable is connected to anything, you disconnect it at the satellite adapter in the trunk. If there isn't a satellite adapter, there's nothing to disconnect.
sofa king
19 Inch
Aug 9, 2015 04:10 PM
wuppiedog
Aug 7, 2015 11:16 AM
andrewvk
Interior
Aug 6, 2015 05:51 PM
socalg35x
Jul 28, 2015 10:42 AM
