AMP SCHEMATICS PLEASE
Old Aug 29, 2004 | 11:32 PM
imRACERX's Avatar
can someone please direct me to how i would go about plugging into the stock amp for power, remote, ground etc etc please? i have a couple w7's and a Brutus 1000 with an awesome box i made and need to carpet, buy a wiring kit and lastly intall it all but dont know ho to go about doing it. i assume i neeed the power wire to directl;y go to the battery for power considering the watts im pushing but the rest should be able to be tapped into the rear audio. please help as i have already replaced the stock speaks with great JBL's and by the way, if anyone still has the Bose speakers, YOU NEED TO REPLACE THEM, it will sound 10 times better. anyway, please help me get this going. i will post pics of the box and then the setup soon thanks RACERX
Clear markers w/ hid bulbs, Sprint springs, B&B Exhaust,JL Audio Hifonics combo.
Old Aug 30, 2004 | 02:29 AM
djrobx's Avatar
Re: AMP SCHEMATICS PLEASE
Check this topic
<a href="https://g35driver.com/forums/showflat.php?Cat=&Board=AudioVideo&Number=234842&p age=0&view=collapsed&sb=5&part=all">PICS - G35 Coupe Adding AMPS & EQ BOSE DIY</a>
I posted the stock bose wiring colors inside.
Old Apr 27, 2005 | 03:04 PM
imRACERX's Avatar
i'm just now finally getting around to doing this install AND the link is gone since the new site went up. anyone else help me on this? i m searching and only find down links to NYCG35 which i originally printed out back then but it is cut off on the sides of the print out and hard to read. thanks RX
Old Apr 29, 2005 | 08:25 PM
imRACERX's Avatar
can someone help on this forum or what? all i need are the chematics so that i can figure out what wires are what and which to use to hook up a coup[le amps. comon help!
Old Apr 30, 2005 | 01:46 PM
rcdash's Avatar
There was a post in this section in the last week with all the pics and the wiring codes etc. Someone reposted NYCG35's pics - just scroll for a page or two...
Old Apr 30, 2005 | 01:57 PM
rcdash's Avatar
ok,
I found it for you:
https://g35driver.com/forums/audio-video-electronics/42803-req-pictorial-diy-running-wire-trunk.html
Old Apr 30, 2005 | 02:00 PM
rcdash's Avatar
And if you just want the post on the wiring colors for speakers and head unit:
https://g35driver.com/forums/showpos...4&postcount=36
- i think the site admins really dropped the ball by losing all the pics for the DIY guides... one of the moderators stated they still had them all, I would have thought a little client side javascript could have done the trick (well maybe more than a little, but it would have saved the rest of us alot of effort such as digging up new sources for old info) - ok enough ranting (sorry)
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
JustinMKN1
Sep 18, 2015 03:40 PM
