PAC AAI-NIS2 not working
Old Jan 14, 2010 | 09:59 AM
Jaybird-runner's Avatar
I have an 04 Coupe with Bose sound system. I installed the PAC AAI-NIS2 unit, connected my iPod, and it does not work. When I push the SAT button all the display ends up saying is Anttena. Anyone have any idea why it is doing this? I have checked and made sure of all my connections were complete.
Old Jan 20, 2010 | 12:28 AM
TimW's Avatar
doesnt it have a switch for sat or no sat? you might have it in the wrong position.
also, sometimes you have to switch to another source like CD or FM, then do back to SAT2 (not SAT1) and the presets 1 and 2 will work.
Old Jan 20, 2010 | 10:29 AM
Thanks Tim, I tried switching it back and forth with no luck. I have also tried all sorts of combos with the buttons (switching from one source to another) and still it comes up Antenna.
Old Jan 20, 2010 | 10:53 AM
TimW's Avatar
After going to Zdayz, I decided I was eventually going to replace the whole OEM setup, and do away with the pac (which I mostly love any other time). When I was driving under tree cover, it would cut out. Since it's fooling the headunit into playing Sat content, if the Sat signal cuts out, so does the pac. When I pull into my garage and sat cuts out for a split second, the pac is muted as well. So, I'm thinking you must actually have an antenna issue... and I know from experience that it will not allow the pac to pass thru.
arora_g35
Apr 16, 2026 02:52 PM
obender66
18 Inch
Mar 13, 2016 12:20 PM
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
JMSABO
Aug 4, 2015 11:58 AM
attarday
Jul 15, 2015 04:03 PM
