Issue with aftermarket sub/amp
Old Feb 4, 2010 | 10:50 AM
liche's Avatar
Originally Posted by lerk
Maybe I didnt explain the wiring like I should, my fault. I have everything wired to the trunk. My RCAs are plugged into a line output converter which is spliced into 4 of the stock sub cables. The REM is spliced into the stock amp power wire. The ground is as solid as it gets.
You don't want to do that. You want to splice before the BOSE amp.
Also, what amplifier are you running?
Also, you'll want to run a dedicated power line from the battery. Do not TAP into the power for the BOSE amp. Also, a remote signal exists on the input harness of the BOSE amp. You can use this.
G35VSHNG37
Oct 25, 2015 08:43 PM
bTanz
Oct 15, 2015 02:31 PM
derres
Aug 28, 2015 03:27 PM
mcneil_g35
Lighting
Aug 5, 2015 01:09 PM
Thunderaan
Jul 22, 2015 07:40 PM
