how to setup key
Old Feb 7, 2010 | 04:43 PM
whoisthis's Avatar
how to setup key
my original key remote is broke so i bought another key remote from ebay.
I got this sheet of KEYFOB ID SETUP WITHOUT CONSULT-ll to make this new remote work, but i doesn't work..
Did anybody try making the new remote work?
Old Feb 7, 2010 | 08:48 PM
VQ Johnny's Avatar
1) Get in the car, lock the doors.
2) Insert the key into the ignition, DO NOT TURN IT, and remove it. Do this at least 6 times in 10 seconds...leave the ley in the 6th time you insert it.
3) The hazards will flash
4) Turn the key to "ACC"
5) Push a lock OR unlock button on your remote...the hazards will flash to indicate it picked up that signal, and that remote is programmed.
That remote is done...if you have NO MORE to program, the remove the keys, unlock the door, and open it. Try the remote, it should work fine.
IF YOU HAVE A SECOND REMOTE...the do the following:
6) After step #5, hit the unlock button on the door, then hit the lock button.
7) Now push either the lock OR unlock button on the second remote...the hazards will flash to indicate it picked up the signal, and remote #2 is programmed.
Old Feb 7, 2010 | 09:33 PM
whoisthis's Avatar
nopenopenopenopenope.. doesn't work.
i tried so many times but i'm stuck with 2nd step. Mayb this remote i bought can't program?
For the 2nd step, do i use the remote that i bought or the old one?
Old Feb 8, 2010 | 12:46 PM
falcor's Avatar
are you trying to program a key fob to unlock/lock the doors or a key
Old Feb 8, 2010 | 01:44 PM
whoisthis's Avatar
tyring to program a key fob to unlock lock alarm and open trunk.
Old Feb 8, 2010 | 01:49 PM
falcor's Avatar
step 2 has nothing to do with the key fob, you don't do anything with the key fob until step 5... step 2 through 4 involve only your key
Old Feb 8, 2010 | 01:54 PM
whoisthis's Avatar
but i still tried from the beginning of the step to the end but nothing worked. I would b happy if key works too lol.
anybody has DIY vid on this..lol
Old Feb 8, 2010 | 02:01 PM
chris d's Avatar
so wait are you having problems getting the hazards to blink? itll take a lot of tries. i know i sat there for 5-10 minutes inserting the key in and out until they blinked. if you got passed that part and turned the key into the ACC position but the new keyfob isnt responding, then you should probably check the keyfob battery. might be dead.
Old Feb 8, 2010 | 08:31 PM
whoisthis's Avatar
trying to get the hazard to blink. do i use the new key or the old one?
Old Feb 8, 2010 | 08:47 PM
dave's Avatar
What key are you using in step #2? It must be a key that will already start the car (a new key will not work for this).
Old Feb 8, 2010 | 09:26 PM
the_sedan's Avatar
consult makes life so much easier. literally a 5 minute process and half of it is waiting on s*** to load up.
Old Feb 8, 2010 | 09:56 PM
chris d's Avatar
like dave said, it has to be the key that starts the car. make sure youre inserting and removing the key completely when doing step 2.
Old Feb 8, 2010 | 10:24 PM
whoisthis's Avatar
so i use the old key for step 2 and when u get to the step where u press any button on fob, u use the new one?
Old Feb 9, 2010 | 01:30 AM
MightyG35's Avatar
you will not be able to use new key. I believe you have to take all of your keys to the dealer to have them programmed. Only the key fob is programmable by us.
Old Feb 9, 2010 | 01:33 AM
whoisthis's Avatar
it costs hundreds of dollars to program keys at dealership...
so after you putting in and out the key in the key cylinder, you press any button on the new key fob?
