car starter using oem key fob?
Old Sep 9, 2004 | 07:48 PM
miecz23's Avatar
Does anyone know if you can interface the factory key fob along w/ a DEI or Clifford car starter
Old Sep 10, 2004 | 06:01 AM
KPierson's Avatar
Re: car starter using oem key fob?
Yes, you need a transponder bypass (DEI model 555U) and a spare, coded key to be permanently mounted in it under the dash.
Kevin
www.KPtechnologies.net
AIM: KPiersonTec
04 DG Coupe / VDC Memory
OEM Remote Window up mod
Procharged / Crawford / TS
Old Sep 10, 2004 | 10:58 AM
miecz23's Avatar
Do you have it installed on your G? What button on the key fob has an aux?
Old Sep 10, 2004 | 11:20 AM
KPierson's Avatar
Sorry, I thought you were talking about the transponder part of the keyfob, not the buttons. A guy by the name of Korz on the board has a DEI I belive that works through X amount of door lock pulses. The major drawback of doing this is the fact that the factory remote have very poor range, especially when compared to the entry level remote start systems. You would be better off ditching the factory keyfob and going completely aftermarket.
Kevin
AIM: KPiersonTec
chinee
Jun 10, 2024 07:48 PM
mjfenix
Aug 17, 2017 05:49 AM
apintojr
Jul 23, 2015 10:52 AM
kenthung
Jul 21, 2015 05:56 AM
