Illumination/Dimmer not working?
Old Sep 11, 2004 | 07:23 PM
vipergda's Avatar
i just pulled out my head unit and atacked the new ac controler i havent put in a new cd player but withought one hooked up my dimmer doesnt work is this right do i have to have the dimmer wire hooked into a cd player for the rest of my stuff to work. i am planing on doing a carpc and not putting in a cd player what would i have to do to get the dimmer to work again or is there something else wrong
thanks for any help you could give me
Old Sep 12, 2004 | 10:29 AM
vipergda's Avatar
Re: Illumination/Dimmer not working?
some one has to have notised this any help would be good thanks
Old Sep 12, 2004 | 02:21 PM
djrobx's Avatar
Are you sure your dimmer isn't just set to full brightness?
-- Rob
Old Sep 12, 2004 | 07:49 PM
vipergda's Avatar
yes i can put it all the way up or down and nothing changes
Old Sep 12, 2004 | 08:00 PM
RamboRami's Avatar
G35driver.com Moderator
i just dont understand your question... you attacked the AC controller?
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake/AVIC-N1-double-din
Old Sep 12, 2004 | 08:03 PM
RamboRami's Avatar
ok after further thought... to answer your question.... No you dont have to have the dimmer wire connected to a headunit for the dash lights to light up or dim. The dimmer wire will only dim what it is connected to... the headunit
something else is wrong with your system, check the fuses first, then pray that a fuse is burnt out, if not- then you blew the dimming bulbs
Old Sep 12, 2004 | 09:55 PM
vipergda's Avatar
thanks for the help i will look into that
Old Sep 12, 2004 | 10:23 PM
narkotic's Avatar
My guess is you shorted something out and messed up the BCM, body control module. It happened to me once on another G35 when messing with the wires that go into the headunit, accidentally shorted them. I hope thats not it though.
Old Sep 13, 2004 | 10:23 AM
GforceI's Avatar
G SQUAD
I may be wrong or maybe you tried this but doesn't the dimmer not work unless the headlights are on? Just a thought...
Old Sep 13, 2004 | 09:57 PM
vipergda's Avatar
i cant believe that was it i am so stupid just had to turn them on thanks for everything
arora_g35
Apr 16, 2026 02:52 PM
obender66
18 Inch
Mar 13, 2016 12:20 PM
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
JMSABO
Aug 4, 2015 11:58 AM
attarday
Jul 15, 2015 04:03 PM
