G35 Key Fob Electrical Problem
Old Mar 22, 2010 | 08:42 PM
KSitler's Avatar
Hello. I am new here and hoping someone can help me. I have an 05 G35 coupe. Around Thanksgiving, my key fob stopped working while I was out of town on vacation. When I got home I tried the other one and it stopped working too. I read online that it was probably the battery in one of the fobs, so I replaced both and tried to reprogram the remotes. I could only get through the first step (key in and out 6 times, then lights flash) and could get no further with it. I finally gave up and went to the dealership. They could not reprogram my remotes either. They even tried to program brand new remotes to the car and they would not work either. THe only thing they could tell me is it was an Electrical problem and I would need to come back so they could play with it to figure out what the problem was. Has anyone has this problem before? Any suggestions as what to look for before I pay the dealership and arm and a leg to fix this?!?!? Thanks so much!
Old May 8, 2010 | 03:37 PM
conesweeper's Avatar
Hey did you figure out what the problem is? I'm having the same issue as you. It started after I had my windshield replaced, don't know if that has something to do with it. I also can't get past the reprogram step where the key is inserted 6 times and the hazards flash, once I put the key in and turn the ignition to ACC nothing happens.
Old May 10, 2010 | 05:44 PM
KSitler's Avatar
No fix yet...
I have not been able to figure this out. The dealership said they would need to hook the car up to a machine to figure out exactly what was wrong with it. Honestly did not feel like spending the money yet...I will definitely post if I ever do figure it out
Old Sep 30, 2010 | 07:37 PM
si_driver's Avatar
got it fixed yet?
This just happened to me this morning, both key fobs stopped working and I can't reprogram them.
Any ideas on the fix?
Old Jun 16, 2011 | 06:43 PM
blAk mAx's Avatar
having issues
Old Oct 2, 2011 | 04:07 PM
crashnburn's Avatar
had same thing happen to me and the next day they just work fine and have since.. but now i have my hazards goin off for no reason.. im thinkin its my bcm and have to get a new one..
Old Aug 18, 2012 | 10:09 PM
QDIZZLE32's Avatar
wow i have the same issue the remotes just wont program .. they just stop working. i replaced the battery in both. did the steps they just wont do it.. and im not goin to the dealer forget that. ill sale the car first. 2006, G35 coupe 6mt 58k miles mint... im goin to reset the cars ecm ecu by disconnecting the battery for 2weeks an see if it will wake up the remote programmer after i connect the battery back.. will let u know soon as i get back..
Old Sep 8, 2012 | 06:01 PM
Pcbrev600's Avatar
This just happened to me today. Both fobs won't work. Tried reprogramming and stlill nothing. Check fuses but windows and door locks work from inside car so I'm sure it's the fob.
Old Nov 2, 2012 | 03:35 PM
si_driver's Avatar
In case anyone still read this old post.
Same thing happens to me when it rains hard or for a long time. (like a day).
Nothing works for a few days when the weather is warm but a little longer when cold.
My guess sometimes is getting wet and interfering with the signal. Not the remote signal, but the Communication signal in the car on the CAN lines.
This has happened to me again just a few days ago after the Sandy came by.
chinee
Jun 10, 2024 07:48 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
apintojr
Jul 23, 2015 10:52 AM
attarday
Jul 15, 2015 04:03 PM
