sub install for non-bose.
Old Mar 29, 2010 | 09:30 PM
shakewell519's Avatar
What do i need to do to install an amp for a sub for a 05 coupe with non bose?
Old Mar 30, 2010 | 03:51 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Amp that supports speaker-level inputs
Amp power wiring kit
Speaker wire
Old Mar 30, 2010 | 06:29 AM
SlickFrost's Avatar
treat it as any normal base car in your situation.. if you want to keep a stock headunit get a high output rca converter run it to your door speaker.. then everything else is normal amp,kit, etc..
Old Mar 30, 2010 | 12:27 PM
iTzTeddy's Avatar
I was about to do the same crap but the JL audio converter was going to charge me like a couple hundred bucks, so I said eff it, I'm doing an DD upgrade + sub install. Try finding a JL audio cleansweep around, I heard those are pretty good.
Old Mar 30, 2010 | 12:56 PM
35Alive's Avatar
Speaker wire
Don't forget the sub lol.
EDIT: Oh and enclosure, my bad.
Old Mar 30, 2010 | 05:12 PM
Well im going to eventually add a dd headunit and an 4 channel amp and speakers. But I unfortunately cannot until later down the road. I already have a 2 channel kenwood amp and jl w3 sub. I was just wondering how to run connect the signal to the amp from the headunit.
Old Mar 30, 2010 | 05:26 PM
The question was installing an AMP for a sub. He said nothing about a sub.
Old Mar 30, 2010 | 05:29 PM
Since there's no line out on the factory base headunit, if your amp doesn't have speaker-level inputs, you'll need a line output converter. Either way you'll have to tap one or both of the rear speakers for your signal.
Old Mar 30, 2010 | 06:36 PM
OK. I just looked at my amp and it does have speaker level inputs.
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
