Wiring diagram
Old Apr 6, 2010 | 04:26 PM
shakewell519's Avatar
Wiring diagram
Does anyone know of a wiring diagram for an 05 coupe with non-bose headunit? Im trying to connect a LOC to it.
Thanks
Old Apr 6, 2010 | 04:44 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
http://www.psedog.com/cars/fsm/g35/coupe/2005/av.pdf
Old Apr 6, 2010 | 08:16 PM
Thanks, so is number 10 slot (light green) wire the one I need to use to hook up the remote wire?
Old Apr 7, 2010 | 05:45 PM
It'd probably work fine.
Old Apr 7, 2010 | 06:39 PM
Ok I finally completed this project of hookin up the LOC. When I put everything back together the CD player doesnt work. Everything else does except the cd player.
Old Apr 8, 2010 | 01:42 PM
It doesn't function or you get no sound when the CD plays?
Old Apr 8, 2010 | 02:04 PM
It doesn not function. When I hit the cd button it says cd then it makes a noise as in the changer is moving then it cuts off. Then if I press the load button it tells me to eject and when I hit that button it turns off.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
master111
Oct 6, 2015 01:36 AM
9tray turbo
Sep 29, 2015 10:22 PM
the93owner
Sep 28, 2015 10:37 PM
