Where to connect lead wire?
Old Apr 16, 2010 | 02:31 PM
plonka's Avatar
I have the stock non Bose head unit and the guy at Crutchfield said to connect the "Turn on Lead" to ignition fuse box for power since the head unit doesn't have a place to connect it. Can anyone be specific as to where this connection is etc... Thanks!
Old Apr 16, 2010 | 07:29 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Being slightly more specific about your application might help.
Like: what you're turning on, where it's going to be... coupe/sedan...
Effort in questions is directly proportional to effort in answers.
Old Apr 16, 2010 | 11:32 PM
plonka's Avatar
The lead wire i'm refering to is from an aftermarket 2 channel amp to power aftermarket 6X9s' that i'll be putting on the rear deck where the Bose 6X9s' would be. The factory head unit doesn't have RCA connectors, so i'm tapping into the rear side panel speakers (06 6MT Coupe) I was told to run the lead wire from the amp to the ignition fuse for power because the stock head unit doesn't have a place to connect the lead. My question is, where is this ignition fuse that i'm supposed to tap into.
Old Apr 17, 2010 | 04:13 PM
Bauer418's Avatar
You should just tap into the accessory wire which I believe is the black/white wire on the ignition harness. Never tap a wire without properly testing it first, but the wire you'll want should read at +12v when the key is turned to "ACC," "ON" (AKA whenever you turn the key to listen to your radio or the car is running).
Old Apr 17, 2010 | 11:37 PM
plonka's Avatar
Hey , thanks for the heads up. I was told i can just tap into the cig lighter. Now i just have to gut the rear interior. Fun times.
Marlin84
Apr 1, 2020 12:52 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
dcsbh1
Oct 1, 2015 03:15 PM
vamarris
Sep 26, 2015 12:56 PM
