pioneer dd issues
Old May 7, 2010 | 03:41 PM
sticktodascript's Avatar
pioneer dd issues
i just had my Pioneer avh p3200dvd installed in my 03 coupe. Everything works fine except for the video/photo playback. I had the headuint installed with a bypass relay not an actual switch. When playing a DVD or accessing movies via an SD card all I get is audio. The warning message pops up occasionally while the audio continues to play. Has anyone run into this issue? The relay and all wires are connected correctly(again, I bypasses the e brake)
Old May 7, 2010 | 07:18 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Ummmm.... did you wire it so that it's showing your (non-existent) rearview camera?
That's the only way I can think of that would screw up the DVD playback.
Old May 7, 2010 | 07:41 PM
yes
it is showing my rear view cam (which i dont have).....how does that cause the issue?
Old May 7, 2010 | 07:59 PM
If your bypass used the wrong wire attached to the reverse wire, the headunit thinks you're in reverse and switches to the rearview camera whenever you're not in a screen that overrides the rearview camera.
Fix whatever you did for the bypass and you should be fine.
hdmark
Apr 29, 2019 04:31 PM
cmesidewayz
Sep 29, 2015 09:28 PM
kevintandmd
Sep 3, 2015 06:41 PM
UT G35
Sep 3, 2015 03:58 PM
