HELP! Trying to install AMP!
Old May 13, 2010 | 07:36 PM
Kingfanpaul@sta's Avatar
I am trying to install an amp and subwoofer, I just removed the blue wiring harness from the stock BOSE amp. Do I just remove the +/- Left and Right Rear speaker wires and convert to RCA or do I still keep it hooked up to the wiring harness and then splice it so I have it still connected to harness but also connected to the RCAs?
Also I have an RCA wire that came with my amp kit, it has RCAs on both sides, can I just cut off the RCAs from one end and splice the ends together with the wires I spliced from the harness?
Old May 15, 2010 | 09:06 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Yes, convert to RCA and yes, you can cut them. if you're still using the stock headunit though, you're still likely to get bad sound due to the balanced signal that the Bose headunit puts out.
Old May 19, 2010 | 12:36 PM
1trueG's Avatar
You will need to splice it so your rear speakers will still work, unless you dont want them to. You will also need to splice for the remote turn on. And I believe you can just cut off the RCA plugs on one side.
Old May 19, 2010 | 01:55 PM
There's quite a few JL audio amps that have input signal sensing, so a remote turn on isn't necessary.
hdmark
Apr 29, 2019 04:31 PM
zoop425
Mar 29, 2016 05:51 PM
broke_as_ajoke
Nov 6, 2015 11:49 PM
Bean_VQ35DE
Aug 22, 2015 09:56 PM
Thunderaan
Jul 22, 2015 07:40 PM
