5 channel amp
Old May 23, 2010 | 07:58 PM
A G Driver's Avatar
5 channel amp
i am looking for a good 5 channel amp to run Infinity Kappa 63.9i (front) and 652.9i (back) and a JL 13W6v2.
i was thinking JL Audio HD900/5..... any thoughts?
Old May 23, 2010 | 10:45 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Yeah, that sub is going to dominate those speakers. Might as well keep them stock.
The Kappas aren't very great at low-mid range, but have very crisp highs, I think you'd be missing some of what you want to hear with that combination.
I had 63.9's in my old car, and they sounded good, but they were combined with Kappa 6x9's, which filled in what the front speakers were missing.
But amp-wise, that should be fine. Plenty of headroom with the 100w RMS for the full-range gives you some headroom. No headroom on the sub, but 500w should push it fairly well.
Old May 23, 2010 | 11:32 PM
Oh, and just one more thing - if space is limited, the 900/5 is a great choice, but you can get a JL 500/1 and JL 450/4 for less.
Old May 25, 2010 | 07:53 PM
Canadian G's Avatar
The Alpine PDX-5 is also a decent amp. Very compact as well
Old May 25, 2010 | 08:19 PM
Raaaaaaaandy's Avatar
or a kicker zx700.5 if you want to go a little more economical...
Old May 29, 2010 | 08:24 PM
A G Driver's Avatar
cool,
what would be a good set up if i got 2 amps???
i don't know whats good or not :/
Old May 29, 2010 | 10:40 PM
Two amps is a good way, it gives you more flexibility at the cost of a little complexity in installation.
I went with both a JL 350/4 and a JL 500/1.
Old May 30, 2010 | 11:47 AM
A G Driver's Avatar
would a JL 500/1 be enough for the 13w6v2?
Old May 30, 2010 | 11:53 AM
According to JL's chart here:
Green (Minimum):
From a reliability standpoint, this zone represents a very comfortable operating power range for each driver. This level of power will not stress the woofer but will not extract all of its performance potential, either.
Use of less than the minimum power level will not damage the woofer, but may result in unsatisfactory performance.
Yellow (Optimum):
This zone represents the best compromise between long-term reliability, high-output and low-
distortion performance. This power level is lower than the woofer's continuous power rating(as published in its specifications), but you will still be taking advantage of the woofer's, low-distortion performance range without undue risk of failure.
Red (Danger Zone):
Slightly more SPL will be gained by pushing the power intothis zone, but typically not more than 2dB, compared to the yellow zone. The subwoofer driver is designed to operate safely up to this power range, but not beyond. Operate with caution.
Black (Warranty Void):
We do not recommend operating woofers at this level of power. In this zone, there is a very high probability that the driver will fail due to excessive heat and/or mechanical stress.
Subwoofer drivers operated at these levels of power are NOT covered under warranty.
Looks like you're in the sweet spot with that combination.
Old May 30, 2010 | 01:34 PM
A G Driver's Avatar
hell yeah
THANKS MAN!!
Old Jun 1, 2010 | 03:10 PM
saywat?'s Avatar
^^yup the alpine is mean. small and incognito looking
Old Jun 8, 2010 | 07:23 PM
A G Driver's Avatar
also do i need to get a big Battery for what i am running?
Old Jun 9, 2010 | 03:41 AM
Nope.
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
Red G Coupe
Video Share
Sep 28, 2015 06:29 PM
