Help, No Power after DD install
Old Jun 29, 2010 | 04:36 PM
Drew'sG's Avatar
I'm having a problem when i installed my PAC ROEMNIS2 i get no power to the radio. i connected yellow, red, and black wires but i get nothing. i connected my PAC to the new radio harness then plugged it into the factory harness. Should I run my own ground?
Car is a 2003 sedan with bose
Old Jun 29, 2010 | 05:02 PM
BacaraG35's Avatar
Check your fuse, then verify power at the harness. If both of those are good, you may have a fault within the radio.
Have you tried to go back to stock to see if tha PAC is bad?
Old Jul 1, 2010 | 06:41 PM
Drew'sG's Avatar
power is good, radio is good. what next?
Old Jul 2, 2010 | 01:10 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Run your own ground, if the red and yellow wires are giving you +12v when the car's on, and the ground is solid, the radio should at least power up.
Old Jul 3, 2010 | 10:06 PM
Drew'sG's Avatar
ok thanks i will try
Old Jul 7, 2010 | 12:09 PM
dj codeman's Avatar
+1 on checkin the ground
willdogs
Dec 8, 2015 11:32 AM
Danielek
Aug 11, 2015 09:33 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
