help...did i just kill my amp?....
Old Oct 5, 2004 | 01:55 PM
klg35's Avatar
set amp(MC300/4) to bridge mode and wired up 2 12" 4ohm subs accordingly to instructions manual........amp is now good for 150x2 and working great.................until, i wired up the 2 subs in parallel to channel A and i forgot to switch the "ohms" switch from 4 to the 2ohms position..........now no sounds from subs, none of the fuses blew and the led stays lit to indicate power coming into amp is ok..........so, what did i fry?,,,,,,,or did i just kill the subs along the way? appreciate any response......thanks.
04 6mt Sedan / stock airbox mod / z-tube / k&n panel filter / crank pulley / 18" r/h c2s / s-tein springs
Old Oct 6, 2004 | 12:47 PM
Rudy's Avatar
Sound Advice
Re: help...did i just kill my amp?....
Bring it by the shop, we can put a meter on the subs and check out the amp. Call Josh at 949-364-6464. If it the Memphis MC-3004 we can get it warrantied for you.
Do you hear me?
Old Oct 7, 2004 | 12:19 AM
klg35's Avatar
if i'm not showing any properties this weekend, i might visit your shop.....thanks.
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
JustinMKN1
Sep 18, 2015 03:40 PM
