need help to install eclipse avn726e
Old Aug 3, 2010 | 12:20 PM
He-man's Avatar
so i am going to install this unit to replace stocky one.
what other harnesses that i might need to complete this installation?
i got the jdm double din kit from dealership and the eclipse dd unit, not sure whatelse i might need, can someone help please.
also, if you are in socal and have knowledge about doing this, plesae come over give me a hand and i will pay for your time. thanks
Old Aug 3, 2010 | 12:31 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
See the shopping list in the sticky'd posts.
Old Aug 3, 2010 | 02:41 PM
spoolinupblue's Avatar
your going to need the Metra harness for the power to the factory plugs, and an antenna adapter.
This is all in the shopping list in the sticky as stated above.
Old Aug 3, 2010 | 07:07 PM
He-man's Avatar
thanks for the helps guys, not sure if i need those harnesses since the headunit comes with bunch of harnesses and wires. i am new to audio scene so
Old Aug 3, 2010 | 07:15 PM
blazeplacid's Avatar
the eclipse unit will have its own harness(s) coming from the uni
should be..
power / speaker wire harness
a/v harness
sterring wheel control harness
and GPS antenna
power/ speaker harness goes to your metra harness.
Its very easy, its color coded.
Be sure to watch your stipes and solid wires.
I remember the Eclipse harness stripes on the power harness in my wifes car was kinda hard to see the stripes (negative wires).
GPS should be a green rectangle type plug...plug it in and mount the antenna above the factory clock.
A/V should be used if you plan on using an external video display.
steering wheel control....pretty obvious. You have to buy a PAC adapter to keep your factory controls
Old Aug 4, 2010 | 01:57 AM
I mounted my GPS reciever under the clock. If i'm looking at the diagrams right, the factory GPS receiver sits behind the clock.
Old Aug 4, 2010 | 07:28 AM
Did you buy the radio by itself or from like Crutchfield where they throwing everything in?
Old Aug 4, 2010 | 10:28 AM
Here's where I mounted my GPS receiver. No problems with reception, since there's metal below it and no metal above it.
R350k5
Oct 1, 2015 08:41 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
