AVH-P4100DVD on 04 G35C with Bose
Old Aug 14, 2010 | 01:27 PM
kenchan's Avatar
Just got done installing it. finally got rid of the damned cassette deck.
Using the JDM trim, moved the dual climate control button over from the stock HU.
some of you were asking how to unlock the a/c plug on the factory harness.
this is locked state. (you can also see the PAC remote wires being tapped
into the factory harness in the background ).
this is un-locked. you can see that 2 clips on the back are slided back.
I just used a pick-tool.
zip-tied the resistor wiring onto the PAC so that it does not tear apart...
hole for the USB that goes into the cubby. the circle and line is for my EZ
felt how i would cut it (next pict)
here's how it looks inside. the color of the EZ felt is actually closer to
stock but the camera's flash made it look werd...
i decided to use up my normally-closed push switch to do the video bypass
inside the cubby. you can get this little switch from Radioshack. or you
can make an auto one using a relay... or buy a pre-fab'ed one off ebay.
bezel trim to rid the gap between the JDM trim and the HU. this trim came
with the 4100DVD. you can also buy a scosche DD trim from amazon if you
need one.
the trim was mounted onto the JDM trim on the inside using thin double
stick tape and some e-tape. otherwise it will rattle.
another angle.
Old Aug 14, 2010 | 03:14 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
I prefer high-temp hot-melt glue over double stick tape, but otherwise, good install.
I wish they still included the trim with the newer DD units.
Oh, and good shot on the harness the PAC connects to, I might use that one for people confused on how to wire it up.
Old Aug 14, 2010 | 04:36 PM
kenchan's Avatar
i considered glue (i have both the hot and cold temp glues) but for this app doublestick tape was a better choice for me.
and who are you again?
Old Aug 16, 2010 | 12:25 PM
kenchan's Avatar
here's my 4100'S setting using polkaudio 6.5 components on the front and every else Bose.
(type of music: R&B, contemporary jazz, pop, j-pop)
MP3 playback: ASR2
Fader: F1
Loudness: Mid
Bass Booster: +3
Parametric EQ
- Low +10@40Hz Q:1Narrow
- Mid +2@500Hz Q:1Wide
- High -4@3.15KHz Q: 1Narrow
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
JoeMac
Sep 28, 2015 12:28 AM
JustinMKN1
Sep 18, 2015 03:40 PM
