Quick Dash removal Q
Old Aug 17, 2010 | 11:37 AM
brmintz's Avatar
I have seen in a variety of DIY's those who simply remove the plastic piece in front of the DIN for factory integration Ipod install and those who remove the whole unit like for the double DIN installation. What is necessary? Do I have to open both sides of the center console and take the clock screw out and all that or should I be able to pull on the plastic face plate and get it off. I really don't want to break anything!
Thanks
EDIT: 04 6MT BTW
Old Aug 17, 2010 | 10:09 PM
kenchan's Avatar
the sides have tabs that lock onto the dd trim piece from the sides so it would be best to remove the sides to pull the trim out. you'll also need to remove the shifter trim and the clock trim so basically everything,if you want to do it correctly.
Old Aug 18, 2010 | 02:23 PM
saywat?'s Avatar
and loosely remove the side panels and glove box compartment lol. its a bitch
Danielek
May 1, 2022 01:28 PM
master111
Sep 25, 2015 08:32 PM
mtlruss
Lighting
Sep 9, 2015 07:44 PM
