Car will not crank, help needed
Old Aug 28, 2010 | 06:56 PM
Retzius's Avatar
Hey guys,
I need some help, last night I was cleaning up the wiring to my KP deluxe mirror tilt module because I didnt like they way I arranged it the first time around and the car shut off?
Now when I put the key in the ignition I get the beeping but when I turn it all the way it does not start. It does not even click. Its dead.
So, I checked the fuses in the driver kick panel and tested them with a voltmeter and they are all good.
Next, I opened up the hood and tested both fuse boxes on top and behind the battery and those are good too. I don't know what to do? The fuses seem to all check out OK with my voltmeter, I also visually inspected them.
Then I tested the battery at Pepboys and it checked it fine. I can also turn the lights on to my car (another indication the battery is fine).
I am thinking it may be a big relay? Or maybe another fuse I havent looked at? Please point me in the right direction. I doubt its the alternator or starter. I think its going to be a relay or fuse. Thanks.
Old Aug 28, 2010 | 08:06 PM
Retzius's Avatar
Okay, I think I found the blown fuse afterall . I overlooked it without using a flashlight. Its the pink fuse near the top of the battery. Here is a pic.
Can I just resolder the connection or is this asking for trouble? I am asking because all the dealership part stores are closed and I want to drive my car.
The blown fuse is called FL40A IGN SW (ignition switch)
Old Aug 29, 2010 | 04:43 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
That's seriously asking for trouble.
Get a proper one or risk a fire or a part much more expensive to replace than a fuse.
Old Aug 29, 2010 | 06:54 PM
Retzius's Avatar
Thanks Wrathernaut,
I figured I had to replace it, no point in soldering it because then the fuse wont blow out in the event of a short. I will replace it.
However, I still soldered it and the car is working, so at least I know this was the problem. I am not going to drive it until I get the part tomorrow, thanks again.
chinee
Jun 10, 2024 07:48 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
newg37
Jul 26, 2015 09:32 AM
vstypicals
Jul 20, 2015 10:55 PM
