2 Eclipse Aluminum 10s?
Old Oct 14, 2004 | 09:18 PM
ChuckP's Avatar
I just finished a custom box that will sit 2 10" subwoofers, now my question is: what do i fill it with? I was thinking 2 eclipse aluminum SW7104 subs that RMS 400 watts. What do you guys think i should use, i am willing to spend up to $400. Also, i have a JL 500/1 amp, if i get 2-2ohm dual voice coil subs, the highest OHM rating i can get is 2, can the jl 500/ amp push that, or will it clip. Please help me . THX
Old Oct 14, 2004 | 10:20 PM
Birds04G35's Avatar
Re: 2 Eclipse Aluminum 10s?
id go with 2 W6's, i just installed that wiht an Alpine digital 1000/1 and it slams to the point where my stomach hurts.
Old Oct 14, 2004 | 11:03 PM
nuttyprof's Avatar
2 w6 would be waaay too loud. i thikn 2 alum eclise would sound nice and clean...pretty loud too. ive got 1 12" alum eclipse and it is perfect for me.
G35s6mt/TSecu/350Z Springs&Struts/K&Nfilter+Z-tube/StillenDualExhaust /6WireGroundKit/KinetixHighFlow
Old Oct 14, 2004 | 11:38 PM
justICE's Avatar
What are the dimensions and what are the sizes of the holes?
-JustICE
Old Oct 15, 2004 | 12:30 AM
limeg35's Avatar
quote.... "R.I.P.S. stands for "Regulated, Intelligent Power Supply" and is a central feature of JL Audio's “Slash” series amplifiers. The remarkable R.I.P.S. System™ ensures consistent power delivery over a wide range of battery voltages and load impedances.
The bottom line of the R.I.P.S. system is: Optimum power, at any impedance between 1.5 ohm and 4 ohm per channel, at any vehicle voltage between 11V and 14.5V"
got those from JL's website, which means no matter what ohm your sub operated at? it will have same power output, so it really doesnt matter what dual 2 or dual 4 ohm sub you get, the JL's amp will be fine.
03 coupe 5AT DG/G premium,performance,
AVIC N1, Volk GT-7
Old Oct 15, 2004 | 01:19 AM
clayton_bigsby's Avatar
idq's. you won't be disappointed
Old Oct 15, 2004 | 02:21 AM
ChuckP's Avatar
My box fills the area under the rear deck, each chamber is .75 cu/ft. Thanks for the input
Old Nov 3, 2004 | 12:39 AM
TedRuxpin's Avatar
Eclipse will be legit. I got some 87081..8 ohm 8" a pair of them..myf riends think they are 2 tens.
g.spot
May 9, 2016 10:54 PM
alessandro
Oct 8, 2015 09:29 AM
blnewt
Sep 25, 2015 01:48 PM
SuperSaiyan
Sep 23, 2015 06:13 PM
