Am I missing something? Please help me out...:(
Old Sep 21, 2010 | 07:27 PM
G35SedanGrn's Avatar
Hi, so I was planning on getting something like this -->http://www.g35parts.com/G35-iPod-Fac...999u7-ipod.htm (Quickest link I could find) and I took out the liner in my trunk just to see what the conector looks like (I was sure I had it)..but i didnt find any conectors or anything...am i looking in the wrong place? i thought if you have the sat button then you have the conector... here are a few pics of what i found.
Sat button
Bose if that changes anything
only wire back thr...
and its a 2003.5 so no doggy door
Sorry for such a noob post but im curious...and if i cant use the sat ipod integration then what can i use? thats still "hardwired"
Old Sep 21, 2010 | 08:40 PM
Unleaded91's Avatar
This is the one I used for my G35: http://www.mp3carpros.com/product_in...roducts_id=203
I bought it from them too..
This unit goes at the back of your stock HU..Its all plug and play..
I also have the SAT and BOSE and Navigation..
Old Sep 21, 2010 | 10:28 PM
hmm looks good i might actually get that...how easy is the install?
Old Sep 21, 2010 | 11:46 PM
Unleaded91's Avatar
It took me about 1.5hrs. It was my first time too..
I had to remove the panels on the floor, under the steering wheel, the radio, clock, and glove box. Its not as hard as it sounds.. Just be patient when your doing it..
I chose this route because I didnt want to run wires from the trunk to the center console of the car using the Ipod adapter that connects to the SAT receiver.
Look around this forum and you will see how to remove the panels to be able to get access to the back of the stock head unit.
Old Sep 22, 2010 | 01:39 AM
thanks for the info!! do you have any idea what that wire is in my trunk? cuz its not the sat but its the only one back thr...
Old Sep 22, 2010 | 03:38 AM
Project's Avatar
Look by your amp.....some reason i remember an extra clip on my 03 there. Might have to unbolt the amp and look under it.
Old Sep 22, 2010 | 12:54 PM
you think my sat conector is under my amp?
Old Sep 22, 2010 | 05:24 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Here's where it is in the 05's, I think it's the same place in '03... check back where my wire trails off to:
Old Sep 23, 2010 | 01:25 AM
Yeah thats where i was looking for it but as you can see it wasnt thr...which i find weird....but oh well ill take all the liner off my trunk one day and try to find it.
Old Sep 23, 2010 | 07:05 AM
According to the wiring I saw in mine, you'll have to look behind/under the seat, not in the trunk.
Old Sep 23, 2010 | 06:16 PM
aww man infiniti hates me and had to make my car the retarded one out of the bunch haha looks like i will be taking out my seats today
Old Sep 23, 2010 | 06:54 PM
TOOK APART MY TRUNK/REAR SEATS!
only plug i found and not sure it its a plug or if its in use...
Old Sep 23, 2010 | 07:19 PM
That's not it, it should have about 8 wires on it (four audio channels, ground, two data lines, data ground and a "REQ" line.
The 03 and 04 service manuals don't seem to have anything about the satellite other than what pins go into the factory headunit. No location info. It's not until the 2006 service manual that they even show where the satellite radio antenna is.
Old Sep 23, 2010 | 07:20 PM
Some of the 03-04s just had the button but no wiring for the unit, you must be one of the unlucky ones.
Old Sep 23, 2010 | 07:36 PM
darn infiniti hates me lol all that work for nothing haha i guess this is a sign that i need to get new speakers, tweeters, new sub, new amp, & JDM dd for a new DD deck
