Would this audio set up work with stock HU
Old Sep 27, 2010 | 07:19 PM
MTG35guy's Avatar
I would like to know if anyone could tell me if this set up would be compatible with my stock HU and everything I have a Bose with Nav & wired for sat
http://nashville.craigslist.org/ele/1974315028.html
Old Sep 27, 2010 | 08:05 PM
MTG35guy's Avatar
ttt.......
Old Sep 27, 2010 | 09:37 PM
spoolinupblue's Avatar
I cant get the link to work.
Old Sep 27, 2010 | 09:44 PM
nar93da's Avatar
yeah, it will work. Since those amps accept balanced differential inputs you can tap into the low level signal from the head unit.
Old Sep 28, 2010 | 06:54 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
^ +1 JL amps accept differential-balanced signals, so you'll want to use the audio signals going into the bose amp, not the ones coming out.
W7s are nice subs too, I'm a bit wary of the condition of that setup though, the pictures don't look great.
Old Sep 28, 2010 | 09:18 AM
gtoor1990's Avatar
JL is the best for car audio as far as SQ / Clarity but a bit on the pricier side..it would work for your stock unit just make sure you get a good line converter.. i can't recall the name but there are line converters that give out good output almost as much as aftermarket decks... I'm more about SPL so i had 2 kicker 12" L7's with a power acoustik ovn14000d amp... Had to pull out spare tire shave out the bottom and build a custom enclosure to actually push them to maximum efficiency lol
Old Sep 28, 2010 | 10:07 AM
eggyhustles's Avatar
lulz
Old Sep 28, 2010 | 10:47 AM
blazeplacid's Avatar
False
truth
I agree, the set up looks kinda beat up, if possible listen to the set up before you buy it.
Old Sep 28, 2010 | 12:36 PM
No line output converter necessary if you're running the inputs to the Bose amp.
Old Sep 28, 2010 | 12:38 PM
And JL's pretty good (I love mine) but *best*? no. Best for price? Nope, not that either. But they're consistently good.
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
newg37
Jul 26, 2015 09:32 AM
itztwinki3
Jul 24, 2015 03:58 PM
realtalk21
Jul 20, 2015 09:07 AM
