07 sedan+ DD
Lack of real ability to change out the headunit is part of the reason I went with the '05 over a new '10.
I'm not sure if anyone has measured the outputs on the Bose headunit, but I would guess that like the previous generation, it outputs a fairly clean signal. So long as you tap the low-level outputs from the headunit as they enter the amp, you'll have a good source for your subs.
I wish it was straight forward.
The screen is probably not a standard double din size (7" wide x 4" tall"
the controls for the radio are probably attached to the radio somehow.
I think the biggest thing is the AC vents being built into the same plastic parts as the screen.
Cost is probably another thing.
The dash kit is at least $170 for a metra and if you want a JDM kit with ac controls you're looking at around $250-$300.
The price for a 07+ would probably be a bit more.
