Anybody run 1/0 power wire?
Old Oct 9, 2010 | 01:54 PM
LiquidClen's Avatar
How hard was it to fit through the panels? Did everything snap back up afterwards, or would it be better to run a couple 4ga wires? I plan on running about 900W total plus some other minor electronics (fans, a PG TiDD5)
Old Oct 9, 2010 | 02:03 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
I did.
Easy. Yes they go in place, no, it's not better to run two 4 gauge.
Old Oct 9, 2010 | 02:08 PM
LiquidClen's Avatar
cool pictures, glad to know what im up against. Thanks
Old Oct 9, 2010 | 02:23 PM
NMG-4's Avatar
i was thinking on do this too,looks pretty simple,any advice wicht amp kit are good to use.maybe the kicker 0/1 awg.
Old Oct 9, 2010 | 03:04 PM
I used a Tsunami brand dual amp kit, the zip-ties that came with it were crap, but the rest of the kit is quite good.
Old Oct 9, 2010 | 03:11 PM
NMG-4's Avatar
thank you
Old Oct 10, 2010 | 05:07 AM
Sorry I don't have any pics of the battery box area to show how stuff is routed/arranged in there, but it's pretty easy to just cut a small slit in the rubber grommet that all the rest of the wires run through and drop it down through the dash. I think the wire can go along the same path that the SAT radio harness goes to get into the trunk, in addition to the way I routed mine - up and to the top - so that the distribution block could be mounted up on the rear deck.
Danielek
Aug 11, 2015 09:33 AM
Thunderaan
Jul 22, 2015 07:40 PM
