Does anyone know if two 15inch kickers will fit in a 2006 g35 coupe?
Old Oct 14, 2010 | 03:33 PM
blazeplacid's Avatar
Originally Posted by lowso
man that is going to be a loud sound system haha
how much mpg does your car decrease due to the extra weight?
my sub weighs 45 lbs + 25 lbs box + 15lbs amp = 85lbs extra no noticeable mpg loss.
it would be the same as having a 10 year old kid in the back
Old Oct 14, 2010 | 03:35 PM
gtoor1990's Avatar
Don't forget depending on how much current the amp draws the stress on the alternator along with the weight lol.
Old Oct 14, 2010 | 03:36 PM
1400rms sub and 300rms highs
no dimming, no hesitations, no problems
stock alt works fine, keeps everything charged at 14.2- 14.4 volts all day even at 3/4 volume
Old Oct 14, 2010 | 03:39 PM
cdubel01's Avatar
CLUB MODERATOR
I'm running two Optima Yellow tops in the car (one for the car, one for the system in the pic) and I got no issues...no dimming, etc...
Old Oct 14, 2010 | 03:46 PM
gtoor1990's Avatar
14.2 to 14.4 volt's is really good... That's what I was getting at idling well the system was playing it's was dropping down to around 11 to 11.4 volts and sometimes if I put it up real high it would drop to around 10.6 volts and the deck would just reset.
Old Oct 14, 2010 | 03:50 PM
gtoor1990's Avatar
I was running on stock battery I had dimming other then that nothing. I originally bought two optima yellow tops from costco and a 200 amp isolator locally ( to run one in the front and back) ... When I got to taking out the battery I realized it was a reverse terminal ... This was when I first bought my blue coupe lol... I just returned the battery and ran on stock battery
Old Oct 14, 2010 | 06:15 PM
eggyhustles's Avatar
You're look at about 13 cubes once sub and port displacement is accounted for
Get a better 12 like an fi btl
Old Oct 14, 2010 | 10:39 PM
JonJuice's Avatar
lol yeah it'll be loud and i don't think it should be that heavy..
arora_g35
Apr 16, 2026 02:52 PM
nickmcc123
Lights
Oct 7, 2017 12:18 AM
BlackGee35
Jul 23, 2015 01:36 PM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
ResoG35Sedan
Jul 14, 2015 10:30 AM
