ok ive tried searching and havent been able to find anything.. i have a 04 g35x sedan with factory navi.. the headunit took a crap like many on here so i replaced with a pioneer double din .. the navi still worked before i put the tv in. now it doesnt. is there a fuse or a certain way to hook this up?> the dvd unit for the navi still has power and the navi control buttons at night light up very dim.. if i were to guess im not getting constant power to it.. if anyone has done this and can help me i will greatly appreciate it..
Wrathernaut
Gentle Manne of Leisure
close
- Join DateNov 2008
- LocationPennsylvania
iTrader Positive Feedback100
iTrader Feedback Score(5)
Liked:1,050 Times in 618 Posts
So you had a pioneer DDin and it was working, then you added a TV somewhere?
no i had the factory unit, it died.. then replaced with a pioneer unit.. but my factory nav just stopped working once the shop installed the pioneer...
i took it apart today and this is what i saw..
i put this cable to ground..
those two plugs are loose
can anybody provide me some info. maybe as to what cables need to have power in order for the navi to work?
Wrathernaut
close
- Join DateNov 2008
The one harness I see with the cut green and yellow wires is the one that send the audio signal from the navi voice, and won't be used. Could you get a better shot of the other one?
Also, the grounding strap looks really badly connected there.
