JL 13W7 in a G35. Can it be done?
Old Nov 1, 2010 | 02:20 PM
Rusaw's Avatar
When i got my car i bought a JL 13W7. The sub is so big im not sure it will fit. Has anybody ever seen or heard of this being done? The truck is so small yet i would like to use some of it.
Old Nov 1, 2010 | 03:30 PM
blazeplacid's Avatar
12.5" sub fits fine with room to spare in a sedan (box looks awful, its my test box, notice the non pre drilled holes =))
Box is 14" high, im sure you can squeeze a 14.5" or so box in there, measure to be sure.
Old Nov 1, 2010 | 03:53 PM
eggyhustles's Avatar
Ported? hell no
sealed? yes
Old Nov 1, 2010 | 04:27 PM
you can fit 2.5 cubes easy in a sedan
my box is 2 cubes and i still have about 4" on the left side
if its in a coupe it wont work, to small of an area
Old Nov 1, 2010 | 05:01 PM
They need a little more than 2.5.
I never ever go by jl's stats since they always end up sounding peaky.
Old Nov 1, 2010 | 05:42 PM
Rusaw's Avatar
yeah ive got a coupe and i want sealed. Subs last longer and take up less room. I was thinkin if i take out the spare tire(only way i can get the sub in there) i might be able to make it work. I just wanted to know if anybody has heard of it being done. By the looks of the pic up there, the sedan has alot more trunk space.
Old Nov 1, 2010 | 09:01 PM
LiquidClen's Avatar
you could definitely do it if you took the spare out
Old Nov 1, 2010 | 09:09 PM
nar93da's Avatar
Your best bet without taking the spare out is to make a 2 piece box that is ported. You could probably make it sealed but I would be worried about it actually being sealed when the 2 sections are joined together.
Old Nov 1, 2010 | 09:58 PM
gshadyz's Avatar
yes you can do it just gut the hell out of your trunk you will have lots of trunk space
Old Nov 1, 2010 | 11:31 PM
gtoor1990's Avatar
Yes it can be done
Old Nov 2, 2010 | 12:18 AM
g35w22's Avatar
yea it can be done i have two 12w7s ported in my coupe
Old Nov 2, 2010 | 06:11 AM
Rusaw's Avatar
Yeah i dont know about a 2 peice box. Id have to do some lookin into that. I was gonna try my luck with a fiber glass to get all the room out of the spare tire area. Think that would add an easy foot of space. Now if i shouldnt go off the JL specs on the box. What square footing should i go off of? This will be my first fiberglass box so i want to make it right rather than messing it up and haveing to re-build over
Old Nov 4, 2010 | 01:41 PM
frostyg35's Avatar
i did the JL 13.5, the 13tw5 in my sedan. takes up very little room and sounds really good
Old Nov 8, 2010 | 12:03 AM
paky786's Avatar
OVERKILLLLLLL, must sound bad *** tho
Old Nov 8, 2010 | 08:57 AM
Originally Posted by paky786
OVERKILLLLLLL,
riiiiiiighhtttt
