Where do you guys mount your amps??
Old Nov 15, 2010 | 05:05 PM
Unleaded91's Avatar
Hi guys,
I will be installing the following this weekend, but I couldn't decide where to mount my amps.
Here are the stuff I have:
Focal components for fronts
Boston acoustics sc65 for rear panels
Rockford fosgate 10" subs (two of them in a sealed box)
Soundstream 4.920 amp
Pioneer 150w amp (i know its old)
Pioneer P4200dvd
So like the title says, where do you guys usually mount your amps?
backseat?
Please give me your suggestions. Thanks!
Old Nov 15, 2010 | 05:40 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
In a coupe, I'd build a shelf under the rear deck so that the fold-down seats would still be available.
In the sedan, I just put them on the back of the rear seats, since there's no fold-down to lose.
Old Nov 15, 2010 | 05:46 PM
Unleaded91's Avatar
Hehe..I forgot to mention which type I have. My G35 is a 2003 coupe.
I have sealed box that will probably sit right behind the dack seat so I am already going to lose that option.
How hard is it to build a rack under the rear deck in a scale of 1-10?
1= Really easy
2-9=???
10= You need a pro
Old Nov 15, 2010 | 07:05 PM
nar93da's Avatar
Here's an old shot of my set-up. I've since moved the JBL MS-8 under the rear deck and added another Planet Audio tube amp for the sub. I had to make an all new board as it was to short for both amps and I devised a way to make the board easily replaceable if and when my amp set-up changes.
The MS-8 is mounted on drop down brackets that bolt in to where the factory amp bolts to. I used all existing mounting holes. It's just barely visible with the cover in place. I can get some shots for you tom. or something.
Old Nov 15, 2010 | 08:13 PM
Unleaded91's Avatar
Thanks for the pictures everyone!
Please do so..So that I can get more idea on how to go about it.
Old Nov 16, 2010 | 03:25 AM
djfarhan's Avatar
same here:
Old Nov 16, 2010 | 11:25 AM
spoolinupblue's Avatar
I am going to have to check into this....But mine is a huge amp.
Old Nov 16, 2010 | 03:32 PM
There's a surprisingly large amount of room between the trunk carpeting trim and the top of the rear deck, especially if you remove the 6x9s.
Old Nov 16, 2010 | 04:45 PM
w4kj4k's Avatar
ooo I never thought about mounting it on under the shelf. I just mount mine on the back of the seats like these sedan guys
Old Nov 16, 2010 | 08:59 PM
nar93da's Avatar
Here are a few updated one's that I had to take with my phone. The MS-8 is mounted onto a piece of MDF which is then secured to the drop down brackets. I just bent some scrap I had laying around into "C" shaped brackets. I only used 3 brackets because 1 would have gotten in the way of the power, ground, and remote terminals. Keep in mind your gonna have to remove the factory sub and work around the seat belts also. I hope this helps a little.
Old Nov 17, 2010 | 03:08 AM
Unleaded91's Avatar
Thanks for the pics guys..
Now that I've seen it, I think making an amp rack under the rear deck is the best way IMO..
Is it possible to just use the screw holes for the 6x9 in the rear deck to mount the amp rack or I have to drill holes?
Thanks!
Old Nov 17, 2010 | 03:10 AM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
here is where mine are mounted
Old Nov 17, 2010 | 05:47 AM
^ Showoff.
Old Nov 17, 2010 | 08:16 AM
Thanks for the pics, that is exactly what I was looking to do.
cant fit any groceries in there....thats out...SHOWOFF!
