xbox 360 in my car
Old Nov 17, 2010 | 07:08 PM
zoop425's Avatar
xbox 360 in my car
So, I started off with one visor monitor and an n64 in my trunk, I want to take it farther. Im installing an xbox 360 and 3 more monitors (other visor and headrests). I have a few questions. I ordered a 400 Watt power inverter because the 140 watt one I have now that runs of the dc outlet is not enough. The 400 watt one requires a strait line to the battery. How do I make it so that it can not run while the car is off? That is the only thing im worried about. Also, Im not taking power for any of the monitors from the battery, just the fuse box on those..
Old Nov 17, 2010 | 07:19 PM
LordFappington's Avatar
Use a switch.
Old Nov 17, 2010 | 07:39 PM
zoop425's Avatar
Thats very clearly not the answer im looking for.. I would not have asked the question if I wanted to use a switch.
Old Nov 18, 2010 | 02:40 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Run a relay rated for that amount of power running through it that's triggered by the switched cigarette lighter's power wire.
Or plug the thing into a real HDTV at home instead of 7" low-res headrest... cars are not your living room.
Old Nov 18, 2010 | 01:43 PM
zoop425's Avatar
I have another one inside hooked up to my TV.. I dont need this one for that! and Its fun, I like it, and its a good project. Plus its a dvd player, and im going to try to get some kind of media setup going on it. Thanks for the advice of the relay
Old Nov 18, 2010 | 04:02 PM
No problem.
Disagreeing with what you want to do and giving good advice are not mutually exclusive... Just don't do anything you can't un-do and return to stock when you decide that a rolling living room isn't what you bought.
Old Nov 20, 2010 | 07:32 PM
zoop425's Avatar
No problem.
I already know that, the reason why Im doing it is because I do electronics related projects in between big purchases for the car. I have already done so many things that are irreversible (ie monitor in the visor) but hey, it has a backup cam too!
chinee
Jun 10, 2024 07:48 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
marsman328
Northern California
Aug 11, 2015 07:29 PM
newg37
Jul 26, 2015 09:32 AM
Karnicle
Jul 23, 2015 05:08 AM
