FS: USA Spec iPod Adapter
I bought this for my 03 coupe a little over a year ago, but I ended up upgrading every component of the stereo and no longer needed it. It worked great for around 5 months while I had it hooked up. I'm willing to negotiate on price, I'm just trying to make enough to buy some clear corners and pocket a little on the side so around $100 or a little less would be reasonable, I paid $150 for it from Crutchfield. I don't have a problem shipping it, I'm in eastern PA.
I'll check to make sure it says it's compatible with the 07. The steering wheel controls do work in some fashion, but exactly how the adapter works I forget, there's an online manual for it I believe, or if I'm wrong it says in the manual I have somewhere. I'm at school right now, but I'll be home and I'll check this out this weekend. It does charge the iPod.
^ All models will allow you to charge and use the steering wheel controls.
OP it might help if you post the model as there are different features between the PA11-NIS, PA15-NIS, and the INFI model
Pa15 is the upgrade to pa11 and it has text display
but the nis is used to hook up behind the radio
the pa15 inf hooks up into the trunk if that helps anyone
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
