Headlights working, parking and taillights not...
Old Nov 20, 2010 | 05:40 PM
G35xTurbo's Avatar
My headlights are working fine but i have no parking lights or tail lights. Of course I've checked all the fuses and can't find any out. One bit of info, i do have my center console out currently to replace LEDs in my heated seat switches. I also was test wiring LEDs and think that i may have had some power jump through an led (before putting a resistor inline). My air and radio controls also work but those lights are out as well. It seems like it should be fuses but i have checked any that seem to have anything to do with lighting or general electrical with no luck. Any ideas what i should check next or specifically which fuse it would be? Thanks!
Old Nov 20, 2010 | 06:20 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
There's three fuse boxes two in the battery box and the driver kick panel.
Old Nov 20, 2010 | 07:59 PM
G35xTurbo's Avatar
Tried the kick panel and the one in front of the battery box but didn't realize there was another one in there. I'll check it out. Thanks!
Old Nov 20, 2010 | 11:42 PM
G35xTurbo's Avatar
Ok, I don't see another fuse box in the battery area. There is the big black on in front of the battery, but I don't see anymore.
Old Nov 22, 2010 | 12:39 AM
G35xTurbo's Avatar
Found some info on infinitihelp.com so figured I'd post it up on here in case anyone had this same problem. Third fuse box is behind the battery and has fuses for the taillights. I'm going to check them tomorrow and I'll confirm that that was the problem.
Old Nov 22, 2010 | 04:30 PM
Unleaded91's Avatar
I just fixed this problem with my 03 G coupe. The fuse box is not really behind the battery(or at least for my 03 coupe) instead it is located to the left of the battery on the negative pole side. You will have to pull the battery covers to see it..
And yes, the tail light 10A fuse is in there..(there is a spare 10A fuse as well)
Old Nov 27, 2010 | 10:34 AM
G35xTurbo's Avatar
Yep, it was actually pretty easy to fix once I figured out there was a secret fuse box, .
arora_g35
Apr 16, 2026 02:52 PM
Mry
Mar 3, 2023 01:03 AM
joedaddy1
Jul 28, 2015 02:58 PM
Wayne9011
Jul 27, 2015 11:25 AM
attarday
Jul 15, 2015 04:03 PM
