03 radio / ac problem F#$%!!!!!!!!!!!!
Old Nov 28, 2010 | 05:58 PM
kday's Avatar
repost from socal section
After all this time thinking that my G35 was one of the lucky ones with out any tranny, window regulator, door switch or any other infamous g35 issues the day has finally come..
I've encountered the dreaded malfunctioning circuit board
I'm looking to sell my car soon and purchasing a double din is just out of the question..
Can anyone in the socal region help me diagnose or possibly refer me to someone who can help repair the issue?
Old Nov 28, 2010 | 06:43 PM
the_sedan's Avatar
find a used circuit board? sometimes its both the circuit board AND the audio unit since they work hand-in-hand
Old Nov 29, 2010 | 01:59 AM
josh.irvine.6's Avatar
^1. I'd sell ya mine, but.. same boat. DD it is.
Old Nov 30, 2010 | 05:23 PM
kday's Avatar
I was thinking the same but wouldn't most used boards have the same issue?
Old Nov 30, 2010 | 05:54 PM
Kuneff's Avatar
I have one worked when I boxed it up 2 years ago. Can't see it breaking being stuck in a box.
Whats the going rate on a used circuit board???
Old Nov 30, 2010 | 09:14 PM
the_sedan's Avatar
nm i would think. u can pick up used audio units for around 100-200 from what ive seen. its common for the boards to go bad, but its not in EVERY car. mine is still workin in my 04
Old Nov 30, 2010 | 10:28 PM
TemjinX2's Avatar
i think you can get it fixed for around $150...its on ebay as a service. I think there located in socal too.
Old Dec 1, 2010 | 03:49 PM
kday's Avatar
I've searched the web and scoured the web and couldn't find anything. Any chance anyone can locate a repair place?
Old Dec 2, 2010 | 10:02 AM
Kuneff's Avatar
I had my 6 disc refurbished by a place that was ran through ebay. Worked out good. If you need the circuit board, I have one... PM me an offer.
Old Dec 2, 2010 | 10:37 AM
mobbdeep1122's Avatar
Check this thread:
https://g35driver.com/forums/audio-v...ml#post5506335
RadioMedics is known to fix this problem for about $275 bucks. They are located in SoCal.
Old Dec 3, 2010 | 01:41 AM
kday's Avatar
Problem solved! I was referred to a friend of a friend who removed, repaired and reinstalled all for $200!
Old Dec 3, 2010 | 07:30 AM
vp-g's Avatar
so what part/s short out?
Old Dec 4, 2010 | 02:57 AM
TemjinX2's Avatar
this is what i was referring too.
http://cgi.ebay.com/ebaymotors/BOSE-...#ht_2028wt_861
Old Dec 4, 2010 | 03:30 PM
hallman's Avatar
Ok I gotta ask. Does anyone know what the exact problem is? By just saying its the "circuit board" doesn't say a lot. Surely there is an electrical tech/engineer that has dealt with this problem. I have an electrical eng. at my job and if it's something like a resistor or capacitor that needs to be refluxed, then this could make for a great write-up
Old Dec 7, 2010 | 01:38 PM
I read that the power supply on the radio itself isn't strong enough to support the radio/AC. Once the power supply is upgraded, the problem is solved.
