crossover question
Old Dec 7, 2010 | 05:18 PM
NjMatteSedan's Avatar
crossover question
i bought new speakers for my front doors. I heard good things about Audiopipe. Here's the link to the speakers
http://cgi.ebay.com/AUDIOPIPE-6-6-5-SPEAKER-LOW-MID-FREQUENCY-LOUDSPEAKER-/370424574767?pt=Car_Speakers&hash=item563f06732f
i'm buying this tweeters for the door pillars
http://cgi.ebay.com/2-CAR-COMPONENT-AUDIOPIPE-100W-1-DOME-AUDIO-TWEETERS-/350374194712?pt=Car_Speakers&hash=item5193edee18
need crossovers for the speakers tweeters. Would this crossovers work for them? also i'm confused wether i need 2way or 3way?
http://cgi.ebay.com/AUDIOPIPE-500-WATT-PASSIVE-3-WAY-4ohm-CROSSOVER-NETWORK-/140477254884?pt=Other_MP3_Player_Accessories&hash=item20b518cce4
http://cgi.ebay.com/AUDIOPIPE-300-WATT-PASSIVE-2-WAY-4ohm-CROSSOVER-NETWORK-/140477254847?pt=Other_MP3_Player_Accessories&hash=item20b518ccbf
Old Dec 7, 2010 | 05:32 PM
eggyhustles's Avatar
Those are ****ing terrible dude lol
If you're gonna go the pro audio route, do it right.
Old Dec 7, 2010 | 05:43 PM
^ i heard those speakers in person they are loud. A reputable shop around me sells them for like 120 per pair. on ebay they're wholesale
Old Dec 7, 2010 | 06:12 PM
Loud is just one piece of the pie
Old Dec 7, 2010 | 06:29 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Mixing components and trying to match crossovers is waaaay above beginner-level stuff.
Those particular components... well, yeah, they got a high sensitivity, so they'll be loud, but I'll take 90db of quality sound over 95db of noise any day.
They look virtually identical to the stock speakers.
Audiopipe may make some good stuff, but I doubt it's the ones that are retailing for $36 each... somebody's making profit on that price, so wholesale is probably more like $25/each. I'm not saying that just because something's expensive it's good, but yeah, I'm going to side with eggyhustles on this one.
I just can't imagine that putting $100 in speakers and tweeters, and another $20 in crossovers... crossovers, mind you, that can't be adjusted, are not specifically made for the frequency ranges of those particular components, and the fact that crossover design and matching to different components is waaay above the level of anybody who has to ask if they need a 2 or 3-way crossover. This is fixing to sound worse than the bose system.
Old Dec 7, 2010 | 06:33 PM
A link on the DIYMA forums...
http://www.diymobileaudio.com/forum/...-opinions.html
Old Dec 7, 2010 | 06:58 PM
Old Dec 7, 2010 | 07:04 PM
What does that prove? getting loud is so damn easy. It probably sounds like ****, though.
Old Dec 7, 2010 | 07:09 PM
sounds clear to me, and this is thru video, which distorts more than in person
Old Dec 7, 2010 | 07:16 PM
Never judge something based off of a video.
You're going about this the wrong way. You need some hefty eq and processing power if you want to mess with pro audio.
Old Dec 7, 2010 | 07:21 PM
never judge something based off its price. I'm not just getting new speakers, i'm getting new amps, EQ, already got a double din etc and i'm getting the setup professionally installed
Old Dec 7, 2010 | 07:26 PM
If i were you, i would just get a comp set. Keep it simple.
Something like
http://www.sonicelectronix.com/item_...se-SC8365.html
http://www.crescendoaudio.com/produc...roductid=17516
Should sound good and get loud. 500 on tap per side should be enough for anyone.
Old Dec 7, 2010 | 08:01 PM
^ yea but if I got a setup like that and used the amp to power my rear coaxial door speakers (1 channel for each door) would it still provide enough power to the 2 front speakers? It wouldn't be 500w per side if I ran my rear speakers to the amp as well
Old Dec 7, 2010 | 08:11 PM
No need for rears
if u feel u really need them, run em off hu power
Old Dec 7, 2010 | 08:41 PM
Well I already bought this audiopipes and I have bad luck selling stuff. I'm gonna get those components you posted and maybe that amp or a similar one and just run the rear doors to the head unit and mount the audiopipes on the rear deck and run em with the 4 channel amp and hopefully everything sounds loud and clear or can I run the audiopipes off the headunit as well and use the amp for the front speakers only?
