Responder One Remote Starter - Door Unlocks on startup. Workaround?
Old Dec 11, 2010 | 09:11 PM
RocG's Avatar
I have a 2007 G35x on which I had a remote starter installed. I have a problem, my car the doors unlock when I remote start the vehicle.
The remote starter is a Python Responder One. The bypass is the iDatalink bypass module.
According to the iDatalink install guides I found online, the fact that the door unlocks when remote starting is a normal part of how this hardware works with this model car. In the iDatalink install manual it's called a "Type 4" install, or "SOLUTION 4 - TAKE OVER CANCELLATION WHEN DOOR IS OPEN."
Does anyone have a solution or workaround to this problem? If I could lock the doors via the remote immediately after I started the car I could probably live with that, but this remote starter doesn't include that functionality.
Is there a way I can get a 2007 g35x to remote start without unlocking the doors?
Old Dec 12, 2010 | 10:35 AM
G35pwrd's Avatar
Does the remote lock your door also? If so there may be a setting in the responder to re-arm/lock after remote start process.
Old Dec 12, 2010 | 11:33 AM
RocG's Avatar
The remote does not have a feature to lock the doors. It does have an "unlock while running" feature. I wonder if this could be reconfigured to lock the door?
Old Dec 12, 2010 | 08:53 PM
KPierson_'s Avatar
Use the starter output to pulse the door lock wire. You'll have to isolate the starter output from the door lock output so it doesn't lock your doors every time you start the car without the remote starter.
In the G the OEM disarm also unlocks the doors. If you could guarantee the OEM alarm will never be armed you can disconnect the factory disarm. Probably not a great idea though....
Old Dec 13, 2010 | 11:09 PM
RocG's Avatar
Thanks for the feedback guys. I'm taking the car back to the installer tomorrow, they are going to see what they can figure out. It sounds like it's something they should be able to fix.
Old Dec 14, 2010 | 10:33 PM
RocG's Avatar
I took the car back to the installer today. They were able to rework things so that the car starts without ever unlocking the doors. It turns out that the doors don't need to be unlocked in order to disarm the system for remote start.
I haven't yet removed the panels to inspect the work again, but the first time around it looked like a quality install. Assuming that the workmanship still up to snuff and the reliability continues, I'll consider myself a happy man.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
