Laser Jammers !
Old Dec 16, 2010 | 03:46 PM
cmesidewayz's Avatar
Laser Jammers !
Im thinking about purchasing a Laser Jammer, does anyone have a DIY or know how to route the wires from the grill through to the inside of the car ?
Old Dec 16, 2010 | 05:32 PM
adamls2's Avatar
Do those still work? Lolz i havnt heard about them in a looong azz time hehe...
Old Dec 16, 2010 | 05:39 PM
P-JDM's Avatar
Most of the ones that I have seen installed are pretty straight forward. Just pull the wires through the firewall and tuck away the ones you have routed to the grill.
Old Dec 16, 2010 | 06:38 PM
Footballmania32's Avatar
Keep in mind, Laser jammers are illegal in all 50 states. As far as wiring diagrams, hopefully someone else can chime in. I'd think the product might come with some generalized schematics on where to run the wires. From there creativity and Macgyver techniques will help a lot Good luck!
-Sean
Old Dec 16, 2010 | 08:38 PM
xeroglock's Avatar
Its illegal to have jammers.. but i think you can still have detectors.
Old Dec 16, 2010 | 09:32 PM
Deepdiver's Avatar
if you're in california, I wouldn't worry about it too much as its only an infraction.
Old Dec 16, 2010 | 10:09 PM
_'s Avatar
_
If the cop gun you and u jam their radar isnt that a automatic pull over for u and have something suspicious? and also i think radars are still illegal thats why some have the VG-2 or spectre for undetectable
Old Dec 17, 2010 | 02:58 PM
rob40wilson03's Avatar
scroll down to #16
http://www.radardetector.net/forums/...-glossary.html
Old Dec 17, 2010 | 03:18 PM
-Sean
laser jammers are legal where im at, orlando. and yeah thats what i might do, creativity always does the trick... im leaning towards the blinder M-25
Old Dec 17, 2010 | 03:21 PM
some jammers put out error readings on their gun. Or when your jammers go off slow down to the speed limit then turn them off and he will get a speed on you
Old Dec 17, 2010 | 03:34 PM
nicbaines's Avatar
if a cop with a laser gun recieves an error reading, he will still know who has the jammer because the salser guns shoot a LASER… it is only capable of hitting one specific target… it dosnt work with the same principals that radars work with.
Old Dec 17, 2010 | 04:54 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Radar jammers are illegal, but lasers aren't.
They'll give error readings until they get a good return. So long as you slow down rapidly but not obviously (no nose dive) you'll be fine, if you're doing like 5mph over and they're trying to catch you in a trap. If you're doing like 20 over, you're screwed anyway. (and an idiot)
Old Dec 17, 2010 | 05:04 PM
RADIOGUY21's Avatar
speeding is also illegal. Laser jammer all the way!
Old Jul 5, 2013 | 12:13 PM
GgHrOeSyT's Avatar
guess yo unever got any advice on laser ajmmer suggestions?
i use the combo escort 9500ci with laser shifters on my g
highly recommend the unit and has worked flawlessly for me. the radar detector has the gps capability so that it is very quiet unless a radar threat is real
i havent run across a laser hit in the 9 mos it has been installed. laser is not very common in VA
i have tested it against a Kustom Prolaser III and it jammed to gun in every instance during testing.
i did the install myself here is the link
https://g35driver.com/forums/audio-v...r-install.html
i have an 06 coupe and had to do a good bit of work with a dremel tool and the grill
but got it to work well and leveled it out with plastic shims. i routed all the wires through the firewall on the passenger side through the grommet there
the grommet is located under the battery compartment. for the rear shifter i have it on the top of the license plate and ran the wire in through the license tag light into the trunk than then through the interior
Last edited by Wrathernaut; Jul 7, 2013 at 08:50 PM. Reason: Don't post-spam. Use a single post instead of 15 for a thought.
Old Jul 5, 2013 | 12:44 PM
Texasscout's Avatar
Lasers are controlled by the FDA, not the FCC (radar) so they are not technically illegal on a federal level. However several states and many cities, towns and municipalities have ordinances against them.
As for the aforementioned Passport, I have 9500xi and it won't do bubkus against laser.
JG_G35
Apr 29, 2016 04:46 AM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
Fire0nic3
Sep 1, 2015 12:12 PM
Frostbite91
Aug 20, 2015 07:20 PM
carid
Group Buys-Vendor
Aug 7, 2015 12:17 PM
