Just hooked up some subs, awesome!
Old Dec 20, 2010 | 01:14 PM
monteitis's Avatar
Bought a Pioneer amp and two 10-inch subs from g35driver member Xsangg last week, and installed them over the weekend! I've never had subs in my trunk before, and I am super pleased with the result.
I wanted to comment on a couple of scattered things I've read over the last week or two about adding subs to the Bose system (coupe).
-I was originally planning on tapping into the wires before the Bose amp and using a LOC (my amp doesn't accept balanced signal), but decided to just hook it all up the "easy" way first, until after the holidays when I feel better about spending $100 on a good LOC. In other words, I tapped into the 6x9 wires AFTER the Bose amp, with no LOC. Much to my surprise, though, I am super happy with how everything turned out and sounds! I have the gain set to "normal" and bass boost off... with fader and bass set to zero at the head unit, and treble at +3, this set-up sounds just about perfect for me. I never put my volume up above 20, so I haven't noticed any bass being cut out passed a certain point, which is what people have complained about with tapping after the bose amp.
If I did want more bass, I can raise the level at the head unit... at +4, I feel like my ribcage is being shattered... I was really only doing this to add some more thump to hip-hop/r&b/dance music, while bringing out a richer bassline in the rock tracks. I'm very happy with the results.
Here are some pictures: I put the amp in the spare tire, but had to raise the trunk floor about 2 inches to have a flat surface.
Attached Thumbnails Just hooked up some subs, awesome!-img-20101219-00035.jpg   Just hooked up some subs, awesome!-img-20101219-00036.jpg
Old Dec 20, 2010 | 01:20 PM
Kuneff's Avatar
In my 03 Coupe I hooked mine up same as you. I blew both rear deck speakers so I put a Rockford 125 and a Pioneer 10. I blew the 10 jammin to some Megadeath on the way to work so I ended up switching to a Boston Amp and Boston Pro 10. WOW it sounded great. That stuff will be going in my Mustang this winter...
Old Dec 20, 2010 | 02:28 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
It's not just a LOC you need, you need something that converts balanced to unbalanced like the MTX REQ. A simple LOC doesn't fix the low-level signal at all.
Old Dec 20, 2010 | 02:29 PM
spoolinupblue's Avatar
Did your Pioneer amp have a high level input or did you just run wire from the stock BOSE sub out to your RCA amp input?
cant really tell from your amp pic.
Old Dec 20, 2010 | 06:55 PM
monteitis's Avatar
@Wrathernaut: Yes I read all about it, which is why I decided to wait until after the holidays so I could purchase a quality LOC that converts balanced to unbalanced... the MTX REQ and the Navone seem to be the ones most people recommend.
@spoolinupblue: Yes, the amp has speaker-level inputs so it was a direct connection. If your amp doesn't have high-level inputs, you'll have to buy a high-low level converter to plug into your amps low-level RCA inputs. The signal is already unbalanced after Bose amp though, so any high-low converter should work.
Old Dec 20, 2010 | 08:02 PM
eggyhustles's Avatar
Spend that money on a deq or a processor
Don't waste anymore money toward a loc
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
MrIP35
Audio/Video/Electronics
Nov 8, 2015 10:47 AM
