AV Electronic Tuner Install Q's
hey,
I have received my AV Electronic TV Tuner and want to get it installed. I was just wondering if anyone knew what other equipment I would need to buy for the install. Does the audio/video need improvement in quality? If so, is there anything I need that can improve the audio/video quality? I remember reading something about improving the video somehow but i cant find the thread or am I over worried cuz the video will probably be good enough. also, I read something about using a cassette adapter for the sound because it will be better than using the fm modulation. is this true? Is there a way to wire the cassette so its not cluttering my console with the wire hanging around. Do I need any additional cables. I think I might need a power inverter. can anyone suggest a good inverter to use? One that is not too noisy or doesnt decrease the performance of the car. Can anyone also give tips/advice on hooking up a modded xbox to the unit? how much would a typical install be if i got it done? any advice is appreciated. thanks
misterg35tee
04' G35C 6MT TwilightBlue/Willow/Prem/Nav/SG
misterg35tee
Re: AV Electronic Tuner Install Q's
You need to get an invertor with at least 200 watts peak power. The good ones have built-in fans that you'll be able to hear if your stereo and the car are off. When I'm driving or I have my volume at 10 or above I can't hear my fan. Get the PAC audio upgrade, don't use the fm modulator or the cassette adaptor.
Russ
Black 6MT Coupe
Jax, FL
G35Driver.com Business Cards
Russ
Black 6MT Coupe
Jax, FL
Machine Head
Sep 4, 2015 07:22 PM
