Having trouble with AMP+Subs installation.
So i got a stock radio.
I just went to a audio shop to get a base amp channel (Red+White plugs) install plug for my amp.
I got a Nitro 600W amp, and a Q-power Sub.
I installed everything, Power, ground and remote on the amp.
Connected it to the subs and it wasnt banging normal.
The subs were working but it was working in a WEIRD way. It was banging very rough and not smooth like how subs are suppose to hit.
I hooked up the subs into a different car and it works really good.
btw i got the amp and subs for free, and i know Nitro amps sucks.
Anyone know whats the problem is?
If you need pictures upon request i can provide them in the daytime tomorrow.
Update with Picture
Sorry for the long wait, i finally have time for this and so here it is lets down to business and got some pics in as well.
What headunit, Bose or non-bose?
It is a stock Bose audio.
WTF is a "base amp channel (Red+White plugs) install plug for my amp"? Just wires that end in an RCA terminal? a LOC? an JBL MS-8?
I just figured it out. It is a LOC
LINE OUTPUT CONVERTOR. i figured out what that is called
Ground, Power REM, +12V(in order)
and btw my friend had this before and he said it was banging normal how subs should of been.
i try mixing up the subs wires and try to get it work. And also tried to mix up the Red and White wire as well and still had no luck
Update with Picture
Swapping polarity of the wires wouldn't make it sound bad. Being a POS amp and sub though. Just because something's free doesn't mean it's better than nothing.
Some more basic info is needed here.
Where are you tapping the audio signal?
What gauge wire?
Where and how did you ground the wire (pics are great with this one)?
Knowing none of that basic info, I'd almost just say you've got either a post-bose tap to the ruined-by-bose speaker level input going into a low-level input on the amp, or you're tapping the pre-bose amp signal (a differential-balanced signal) and feeding it to a crappy amp that can't handle that type of signal.
What gauge wire?
Im pretty sure its connected correctly. i can provide a picture of everything wired tomorrow so you guys can spot me for errors.
Double check that the wires aren't crossed. If the subs are working but not sounding correct then it might be as simple as having the wiring mixed up. If you have the negative terminal from the amp going to te positive terminal on the sub, the sub will work but sound "weird" like you described. It's unlikely to be that simple, but sometimes it really is.
My power gauge is huge. Had a hard time getting the wire into the car.
It's most likely your amp settings, make sure you're the switch is on LPF instead of HPF if you have that option.
so i played with the Positive and Negative wires for the sub, its still not sounding right =(.
and yeah these amp is cheap *** **** lol, im planning to switch em out later. But first i just need to get these subs to work so i can play some hard music for now.
What gauge wire?
What gauge wire?
try another sub or speaker with the amp hooked up the same way
id use atleast 6" or so to get some excursion
if the new "sub" is making the same noise, then its probably your amp settings or the signal to the amp
did you tap into the speakers and use the high level inputs on the amp?
