ALMOST done with install of DD amp and speakers!! still need help please asap
Ok...hooked up my amp...front components....sub...receiver...all seem to work...the fronts and sub is playing a CD....
However the Radio Antenna will not pick up any stations at all..
also there is a pretty loud humming sound when the ignition is ON.....sounds like it is coming from outside the car....
and........the ASWC does not work.....I hooked it up like it said to do but I didnt take the #11 pin and hook it into ground...I guess I need to do that by cutting the wire from harness and hooking into ground...
lastly the parking brake.....I found the bunch of wires right above the parking brake but do I hook up the light green PB wire to the light green wire....or to the GREEN wire?
thanks so much I hope I can get this finished today I am excited...built my own sub box and all...
If you can't pick up any radio stations, make sure your antenna adapter is secure in the radio and to the old antenna wire. If those are good, make sure you are powering the antenna amplifier. The Metra (or PAC) harness will label it power antenna. It needs to be connected to the same wire as the amplifier power signal wire.
Thunderaan
Jul 22, 2015 07:40 PM
