audio question g35 2006 w/base head unit
Old Mar 21, 2011 | 09:09 PM
Iagent's Avatar
I'm adding an amp (nothing huge), but just an amp. Where do most of you get your power source?
Back in the day, I would tap the battery or fuse block, but this car seems a bit more crowded and sealed up to run wires outside of the car. The fuse block seems buriedd as well.
Thanks for the help.
Old Mar 21, 2011 | 09:21 PM
2sik4ag's Avatar
ur power u can run it from the battery, ull have to take the battery cover out, the look underneath ur glove box, n follow the factory harness out the front, n that will b where u plug ur wire thru..... n 4 the neg n ur remote u can top ur factory amp that located in the trunk, where ull of course would need to top the amp for ur high/low wires.....
nickmcc123
Lights
Oct 7, 2017 12:18 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
mjfenix
Jul 14, 2015 10:37 PM
