Help Hooking up AAI-NIS
Can anyone tell me where I connect the blue/red and blue/black wires to? This is what the manual says:
Blue/Red wire: Aux 1 remote output. This wire provides a negative output when radio is in Aux 1. (300 mA max output, use relay when necessary)
Blue/Black wire: Aux 2 remote output. This wire provides a negative output when radio is in Aux 2. (300 mA max output, use relay when necessary)
For now, I only plan on connecting a PS2 to Aux 1. Is the blue/red wire just like a 12V remote wire for an audio amp? Do I have to connect the Blue/Black wire as well even if I am not using Aux 2? Thanks guys
Black 5AT Coupe, Navi, Falken Koblenz 19", HKS Legamax Exhaust, ZTube/Stillen, Grounding Kit, RSR Springs, Tokico DSpec Shocks
Re: Help Hooking up AAI-NIS
In you application you don't need to do anything to those wires. You could if you were using a dvd player have power applied when you selected aux 1 or 2. That is basically what those wires are for.
JT
JT Audio & Accessories
118 S. Loara Street
Anaheim, Ca. 92802
(714)817-8282
JT
118 S. Loara Street
Anaheim, Ca. 92802
(714)817-8282
So those wires are +12V remote outputs for turning on car A/V equipment? But it would not work for a PS2 or iPod unless I had a relay connected to the switching circuit of my PS2 or iPod?
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
