Head unit going out?
Old Apr 2, 2011 | 10:25 PM
jonesmeister11's Avatar
I'm already going to assume that the Bose head unit on my 03 coupe is going out. It started with the CD error. I switched to the cassette player with iphone. Now i constantly get the code tape error. Sometimes the cassette gets stuck, some times not. When the tape is actually playing it is constantly switching from side 1 to side 2. Then following a tape error. Sometimes only the right speakers work (stock subs still work) The other day There was a pop and the speakers stopped working with the tape player. I switched to the radio and the speakers were working normal.
I switched to the radio, now randomly the music will totally cut out and there will be no sound. I know its not radio silence, because I can switch stations with no sound.
Then the head unit sometimes goes blank where the radio station info should be.(see attached picture)
If i use the sterring wheel control to change the stations sometimes it controls the volume and not changing the station...
My 4th brake light (in the glass) works erotically and the trunk light has stopped working, and yes I have replaced the bulb
Here is a video of my car with the A/C goin on the fritz
So any ideas? ECU, short, or bad head unit?
Old Apr 2, 2011 | 11:34 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Different strokes for different folks, I suppose.
But as for the problem not related to what gets your motor going, yeah, the headunit seems to be shot. Good excuse to go aftermarket.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
Oregon13
Mar 1, 2016 12:06 AM
