Replacing Bose sub
Old Apr 17, 2011 | 05:14 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Originally Posted by obender66
That's all same as "bench racing" -buying products based on printed specs. What about sensitivity? Pioneer has a 3 db advantage due to unique spiderless design. 3db-it's double the amp power. I have only 160 wrms bridged to drive it. I will need 320 wrms amp for JL sub to get same output.(that JL ** disclaimer about sensitivity is lame-laws of physics are laws of physics)
Pioneer's basket is also designed to be mini enclosure, which is a huge benefit in free air installation. I actually hooked it up to home stereo to test it-no baffle at all. It had a nice kick from ancient 30 watt receiver without any crossover ! Nothing you can expect from a sub which is just sitting on the floor.
I do not listen to ghetto "Bass is tha ****e" recordings to care about 25Hz notes. Those 25 hz at what? -6 db?-8db? Did you see the actual curve? Sub is going into factory spot along with few layers of Fat Mat and will sound great. No box!
My first sound off was in 1997 with Pioneer sub and I love their stuff. I was turned off JL products by that bald fvck working for JL who was ****eing on car audio forums about the same time.
I do not deny that JL will sound better, but definitely not $400 better...And I own home audio system pushing well into 5 digits...including 1978 Denon turntable
I reiterate-to each it's own. I just want to present an alternative to other G members.
I don't consider comparing manufacturer's printed specs as "bench racing". If Pioneer says their 8" shallow mount can't go that low, it can't go that low.
I'm not advocating spending $500 on a 8" woofer, especially one that goes in a fairly poor spot like our flimsy rear deck. That's certainly poor value, but using a shallow mount there instead of a normal sub in the same price range is making an unnecessary compromise. That's what I have issues with - unnecessary compromise - not inexpensive parts.
For the same price as the Pioneer 8" shallow mount, you could get a Polk Audio one like this:
http://www.woofersetc.com/p-8129-mm8...subwoofer.aspx
Higher sensitivity, lower frequencies, it's more the direction I'd go.
Old Apr 17, 2011 | 06:14 PM
856_reilly's Avatar
Isn't the stock a free flowing sub? JL I don't think can just be droped into the factory hole. They need a inclosure. Any sub these days is not a free flowing sub. They all need inclosures. If I'm wrong lmk cause I would love to change my factory sub to somthin different.
Old Apr 17, 2011 | 06:19 PM
eggyhustles's Avatar
You are wrong.
Frankieg35's Avatar
I didnt know they came with a sub..
Old Apr 17, 2011 | 06:45 PM
Hotdawwgman's Avatar
The sedans did
Old Apr 17, 2011 | 07:06 PM
856_reilly's Avatar
Originally Posted by eggyhustles
You are wrong.
Ok do you have anything else to say about it other then " I'm wrong" like what will work.
Old Apr 17, 2011 | 07:07 PM
856_reilly's Avatar
The coupes don't have a sub?
Old Apr 17, 2011 | 08:49 PM
g35guy86's Avatar
No not enough room. It has two 6x9s for bass instead, which are terrible for that purpose.
Old Apr 19, 2011 | 09:41 PM
obender66's Avatar
Higher sensitivity, lower frequencies, it's more the direction I'd go.[/QUOTE]
That Polk is a "NO" for free air use. I followed the link.
Just stop by when you get chance to be in Toronto and check out my install. You will not be dissapointed
Daniel k.
Nov 3, 2015 09:52 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Frostbite91
Aug 2, 2015 04:59 PM
kd03g99
Jul 30, 2015 11:24 AM
Thunderaan
Jul 22, 2015 07:40 PM
