Eclipse AVN6620 speed pulse question
Old Apr 25, 2011 | 10:58 PM
g35austin's Avatar
I hooked my AVN6620 up a bout a week ago and my speed has been off according to the system info and it's causing my maps to not be accurate. Is there a way of adjusting this setting?
Old Apr 25, 2011 | 11:21 PM
RRYDE's Avatar
What is not accurate about the maps ?
Old Apr 25, 2011 | 11:41 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Bad speed could be from poor GPS antenna location, or the eclipse may have a speed pulse setting somewhere in the settings - can't say for certain as I haven't used an eclipse stereo in a long time.
The pulse is usually only used to keep the unit on track while you're in a tunnel or otherwise can't get a GPS signal, so again, I'd say it's your GPS antenna that's not getting a solid enough signal, or the unit is still calibrating the speed pulse to the actual speed measured via the GPS signal.
Old Apr 26, 2011 | 09:13 AM
g35austin's Avatar
Wrathernaut- When I did a search on here to see where people were mounting their gps antenna, I think it was you that mounted it under the clock panel. Are you getting a good reading there?
Old Apr 26, 2011 | 09:14 AM
350zspl's Avatar
can you go dead center on the top of the dash
Old Apr 26, 2011 | 11:35 AM
Yes - There's metal directly beneath it (radio bracket arm) and no metal above it. I've never tried it in another location to compare, so I can't say if it's the optimal spot by any means, but it's invisible and hasn't gotten me lost yet.
350zspl - there's not much reason to put it on top of the dash, as the plastic/rubber the dash is made of doesn't block GPS signals.
mtlruss
Dec 20, 2015 01:51 PM
Nicksims13
Oct 15, 2015 01:57 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
