Dynamat the trunk?????
Old May 23, 2011 | 02:43 PM
akaneedles's Avatar
Looking to Dynamat the trunk floor of my 06 coupe.Were is the best place/price online?Then how much do I need for the job?
Old May 23, 2011 | 03:55 PM
The-Dream's Avatar
Old May 23, 2011 | 04:24 PM
akaneedles's Avatar
Thx.
Can I use both together?Fisrt spary down the DAPtex,then apply the damplifer-pro?
Old May 23, 2011 | 05:02 PM
eggyhustles's Avatar
What are you looking to do..get rid of noise?
Old May 23, 2011 | 06:27 PM
akaneedles's Avatar
Well, I'm really looking to quiet down some of the exhaust drone I have.
Old May 23, 2011 | 08:17 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Vibration dampener (like SDS's CLD tiles, Second Skin or *ick* Dynamat) isn't good for reducing low drone. You'll want some closed-cell foam at least, and even better, add some mass-loaded vinyl barrier to cut out exhaust drone.
Here's the best source for both information and products for sound deadening:
http://www.sounddeadenershowdown.com/cgi-bin/index.cgi
Their CLD tiles *rock*!
Dynamat sucks hardcore when compared to the competition.
Old May 23, 2011 | 08:23 PM
The-Dream's Avatar
I'm actually going to buy 80sq.ft of Damplifier Pro for my trunk to reduce road noise. I'm going to try it without all the foam stuff first.
Old May 23, 2011 | 08:53 PM
Unless our trunk has 320 sq. ft of surface area, that's a *HUGE* waste.
Damplifier pro is a vibration dampener, not a noise barrier. Once vibration is controlled (25% coverage) you're using the wrong (and most expensive) tool for the job by doing it that way.
I used about 6 CLD tiles (about 6 sq. feet) in my trunk and nothing vibrates at all.
Old May 23, 2011 | 09:22 PM
nar93da's Avatar
The idea isn't to cover every square inch of surface area with vibration dampener. Like Wrathernaut said above, you only need 25% coverage for a flat surface. If the metal has a bunch of bends and valleys it isn't going to vibrate. That's not to say it won't help in those areas but the return on investment isn't as great.
If you want to make your vehicle quiet you need to use MLV (mass loaded vinyl). I would line the floor and the area behind your seats. It is meant to have no gaps only where necessary. Of course you would still need the dampener with some closed cell foam on it, then the MLV installed on top of everything else.
To be dead honest, I think your throwing your money down the drain on dynamat. Another company to look at is Raamaudio.com. They have a very good dampener (which I use) as well as a closed cell foam (also use) with adhesive on the back already.
In my opinion Damplifier Pro is a waste of money. The regular Damplifier is sufficient and I'm sure other's would agree. Once vibration is controlled, it's controlled the added thickness just equates to more money and isn't needed.
Old May 23, 2011 | 09:52 PM
akaneedles's Avatar
OK were do I get this stuff? -closed-cell foam or mass-loaded vinyl barrier
Old May 23, 2011 | 10:57 PM
nar93da's Avatar
Raamaudio sells CCF(closed cell foam) I would recommend you get the peel & stick. You can find MLV on ebay. I've bought some from soundproofcow.com in the past. Keep in mind that MVL is very heavy for what it is. The roll I have is 2lbs. per square foot, while most is 1lbs per square foot. Shipping will be expensive for MLV.
In my last order from rammaudio I bought one pack of 37.5 sq ft. of deadener and 3 yards of P & S CCF and I think it was around $160 shipped to my door. You should be able to do your whole car with 37.5 sq ft as long as you only put it where needed.
Old May 23, 2011 | 11:14 PM
The-Dream's Avatar
So would you suggest using Damplifier and then MLV on top of it? I'm scared it would be too thick and I can't put all the panels back.
I wanted to buy a bunch now in case I wanted to do other areas of the car.
Old May 23, 2011 | 11:46 PM
akaneedles's Avatar
Said it comes "14 sq ft per running yard, 56" wide!"
How much do I need?
Old May 24, 2011 | 08:56 PM
nar93da's Avatar
How much do I need?
Best thing to do is measure the area you want to cover and do a little math. That foam is great for stopping rattles and such in between panels.
I would only put the MLV on entire floor if you were going to do it. I know for a fact you can place it behind the door panel as you can't get it back on. It's best to use CCF to decouple the MLV.
Instead of me just typing, it's time to do some research. Here are some links for good reads. Should keep anyone busy for a while.
http://www.raamaudio.com/index.php?o...&id=3&Itemid=4
Old May 25, 2011 | 12:32 AM
The-Dream's Avatar
I'm just going to thug life it and install B-Quiet Ultimate first. I'll report after it's done but it won't be for awhile though. I still have to install my suspension, wheels, BBK, wait for car to be repainted, and install my DD (shout out to Wrathernaut!).
ara777
Oct 25, 2017 01:45 PM
g.spot
May 9, 2016 10:54 PM
G35xdriver04
Nov 7, 2015 08:31 PM
Albanian122
Sep 7, 2015 07:41 PM
