Remote Start
Old Nov 22, 2004 | 08:03 PM
KDawg15401's Avatar
Remote Start
Does anyone know what wires need to be powered for a G35 to start? I have Ing 1, ACC powered and it still doesn't start.
Old Nov 23, 2004 | 10:01 AM
god_of_cpu's Avatar
StreetDeck.com Developer
Re: Remote Start
Are ya bypassing the immobilizer chip using a spare key?
2003.5 G35 Coupe
Carputer
DigitalWheelz touchscreen
NAV, MP3, CD, DVD, OBD II, RearView Camera, Voice Control
Old Nov 23, 2004 | 05:59 PM
808gcoupe's Avatar
Re: Remote Start
yeah...imobilizer bypass, clutch bypass (if 6mt), and if I can remember correctly, this car needs a second starter (not second ignition) PM Kpierson (sp?) he'll be able to tell you all of the wires you need. I could get a tech sheet but it'll take a while....gotta go to my friends shop to get it and I dont know when Ill have time to go.
Old Nov 23, 2004 | 07:50 PM
KDawg15401's Avatar
Re: Remote Start
Yes I'm bypassing the transponder. I also have a relay to the second starter wire.
Old Dec 1, 2004 | 11:37 PM
KPierson's Avatar
You have all the wires then -
1 accesory
1 ignition
2 starters (2 relays)
Thats it.
What is the car doing? Or not doing? Is it cranking? If it never cranks it could be two things.
1. Starter wires are wrong
2. Clutch bypass is wrong (6mt only)
If the car won't crank one thing you can do is DISCONNECT THE TRANSPONDER RING, start the car with the key, remote start the vehicle (with it running) and then take the key out of the ignition. If everything else is hooked up right the car will continue to run.
You can also try starting it with the clutch depressed. This will eliminate the clutch switch as a possible problem.
If the car cranks but doesn't start it could be your tach signal, your ignition wire, or maybe your accessory wire.
WITH THE TRANSPONDER RING DISCONNECTED put the key in the ignition and turn it to the 'ON' position. Try remote starting it now. If it starts its either a problem with:
1 Ignition
2 Accessory
3 Transponder
The transonder can be further tested by KEEPING THE RING DISCONNECTED and placing the key in the ignition but not turning it at all. This way, the factory ring will pick up a correct code.
If the car starts, runs for 3 seconds or so then shuts down its most likely a transponder issue.
If it is a tach problem there really isn't a way to test for that. Typically there is a 'learn' routine that will tell you if you have the right tach signal.
Give me some more details and we'll get it working.
Old Dec 4, 2004 | 02:59 PM
KDawg15401's Avatar
I got the car to remote start. The problem I'm having now is that if you just start the car with the key, the remote starter doesn't work until you reset it. Do I need a diode on the second starter wire?
Old Dec 7, 2004 | 12:54 AM
KPierson's Avatar
The remote start doesn't work until you reset what?
magnetism80
Feb 1, 2019 10:00 AM
Jnm07
Sep 5, 2015 01:16 AM
jbmw002
Sep 3, 2015 08:42 PM
UT G35
Sep 3, 2015 03:58 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
