NEED HELP ASAP ipod intergration 03 coupe
Old Jul 6, 2011 | 09:54 PM
darkpyro204's Avatar
Exclamation NEED HELP ASAP ipod intergration 03 coupe
recently just bought an 03 g35 with the upgraded bose sound system. i listen to my ipod alot so i went and bought an isimple tranzit. ive removed the head unit and put the isimple in place but my problem is im not very good a reading wire diagrams and i oopsed and took apart one of the connectors so now its just individual wires i just need to know which diagram to look at where the ground and power go on the isimple. the connector i took apart was the bigger of the two that connect to black ports in the back of the head unit
ps im still learning audio but im not completely ignorant
Old Jul 6, 2011 | 10:26 PM
hdmark's Avatar
my guess, if its like the 04 coupe with bose is connect the powe to the red (switched power) which is the ignition switch wire.
screw the ground in somewhere to the chassis.
hopefully more can confirm this for yoU!
Old Jul 6, 2011 | 11:10 PM
know how to rewire the harness? correctly?
Old Jul 7, 2011 | 09:01 AM
hdmark's Avatar
not sure what you mean, but if you are just wondering how to tap into the right wire. there is a red wire on the biggest and widest of the 4 harnesses. that is your switched power (i am 99% sure). strip it back a little and solder on your new power wire from your device and then tape it back up. and the ground. i found a screw below the stereo hole that i believe is ground to the chassis and i just threw the ground in that screw
Old Jul 7, 2011 | 11:51 AM
thx for tht info only thing is on the big harness it actually came apart so the wire are no longer in the harness so what im looking for is actually a picture of wich way the wires goi guess
Old Jul 7, 2011 | 12:04 PM
My Key's Avatar
Jeebus dude.. how did you take the harness apart!!
see if this helps: http://retro.nextmill.net/g35/g35stereodiagram.pdf
Old Jul 7, 2011 | 12:20 PM
i honestly have no idea how i did i have these diagrams but wich one am i looking at the harness i took apart was the biggest one out of the four and it plugs in to the big black port
Old Jul 7, 2011 | 12:31 PM
My Key's Avatar
I know what you're talking about but yeah... Someone's gonna have to take a picture for you to see exactly where the wires go
Old Jul 7, 2011 | 12:34 PM
My Key's Avatar
best one i can find so far:
Old Jul 7, 2011 | 01:47 PM
thanks for that mate unfortunately the 1 is right over the wires i need >.< so im just going to order a new harness and soder the old wires to it... tho i went to an audio store and they told me they were gonna charge me 75 for a reverse harness to trace all the wires and then do it that way told them to have a nice day
Old Jul 8, 2011 | 07:00 AM
http://www.jcwhitney.com/radio-wirin...equestid=96844
Im hopin this will work
Old Jul 8, 2011 | 07:11 AM
Old Jul 8, 2011 | 10:46 AM
My Key's Avatar
lol. are you just going to use it as a reference?
Old Jul 8, 2011 | 08:08 PM
originaly yes i was but i found the reverse harness at bestbuy soo problem solved
trulegend
Audio/Video/Electronics
Jul 31, 2015 03:37 PM
bishop977
Jul 31, 2015 02:29 AM
BlackGee35
Jul 21, 2015 07:24 PM
