Installation help Inf Ref 6030CS
Old Jul 27, 2011 | 03:58 PM
Gatorbait's Avatar
Greetings,
I have non-bose speakers and my right speaker recently blew for the 3rd time, so I decided to get a pair of Infinity Reference 6030CS 6-1/2 to replace my front speakers. I want to install them myself but I think I need a spacer? I went to the zenclosure website to order the spacers and they ask for a mounting hole diameter size, either 5, 5-1/4, 5-1/2, 5-3/4. Is a spacer needed? If so, can someone please help me figure out the size of the mounting hole.
Thanks
http://www.zenclosures.com/Nissan_In...infinitisp.htm
Old Jul 27, 2011 | 06:02 PM
OBsessed's Avatar
What they're looking for, I'm assuming, its the mounting diameter of your new speaker, which is not necessarily same as the cone size (in your case, 6-1/2). If you've already gotten the speakers, you can measure the inner diameter of the mounting ring that came with them to get the size you need.
Alternatively, since you're a DIYer, you can make your own speaker adapters too. Get some 3/4" MDF from Home Depot/Lowes/a friend, trace the outer pattern of the stock speaker, mounting tabs and all, then trace the inner ring of your new speaker's mounting hardware, cut out both and call it a day. When they're done they'll probably look like the ones below, and you don't have to wait for shipping.
Old Jul 27, 2011 | 11:50 PM
magic5g's Avatar
http://www.crutchfield.com/p_1086030...ures_and_specs
It says your cutout is 5 3/8 inches, so I would go with the 5-1/2" spacer. The cutout btw is the diameter of the magnet and bottom of cone that will fit into the hole seen above.
Old Jul 27, 2011 | 11:51 PM
magic5g's Avatar
repost
Old Jul 28, 2011 | 09:34 AM
KnowScott's Avatar
I got those spacers from zen as well, my speaker required 5.4" diameter so I got the 5.5" spacer.
Old Jul 28, 2011 | 11:11 PM
Gatorbait's Avatar
Thanks guys spacer is on the way
Old Jul 29, 2011 | 02:12 AM
magic5g's Avatar
A note in installing the speakers, the screws that came with the spacers are hard to install, since there is a nut that goes on the bolt and you have to screw one of them from behind, forcing you to take apart part of the door. What I found in a guide online somewhere, was to get a self tapping screw (M14 x 1.5-2") and screw that from the spacer straight onto the door. This way, you don't have to mess with anything in the back of the spacers.
https://docs.google.com/viewer?a=v&p...U1&hl=en&pli=1
This guide was most helpful, let me know if you have any questions or need any help.
R350k5
Oct 1, 2015 08:41 PM
gatorglaze
Sep 10, 2015 12:03 PM
Machine Head
Sep 4, 2015 07:22 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
