sub won't work above volume level 12
Old Jul 27, 2011 | 08:46 PM
viet1098's Avatar
Hello all, long time reader first time posting. I searched the forum for re-q5 and such, but nothing specific to my situation. ok, here is my problem.
i have the following installed
RE-Q5
Alpine MRP-M1000 - Amp
Alpine Type-X SWX-1243D
i tapped into the bose connector at the amp, all my input to the re-q5 are pre amp. everything seems to work fine, as long as the volume stay at 12 or below, i tried to reduce the amount of gain both on the re-q5 and amp. above 12 the subwoofer just cut out and go silence, light on amp is still lit. is it my amp that can't handle the load or am i missing something here. please help.
and please excuse the poor english.
Old Jul 27, 2011 | 10:31 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Are you tapped into before or after the Bose amp? The bose amp has heavy bass-cutting EQ built into it that cuts more and more bass as the volume goes up.
If you're before the bose amp, I'd test with another audio source to see if you get the same problem.
Old Jul 27, 2011 | 11:37 PM
magic5g's Avatar
Shouldn't the bass just be just at a lower volume than being completely out?
I would definitely try and single out the problem like wrathernaut said. Because on an opposite note, my speakers go out when the volume is above 20 Try checking your ground cable, switch amps, switch subs, etc. Btw, does it happen on disc and radio? Because my speakers go out when im using CD's but not my iPod so I'm wondering if it's the left channel causing problems since mine has the fading out problem.
I have a scosche loc, mrp-f550 alpine type x 177a components, mrd-m1000 and 2 idq10's.
Old Jul 28, 2011 | 01:13 AM
SuperCleanG's Avatar
This is usually not enough power to meet the needs of the equipment (speakers)
Old Jul 28, 2011 | 05:17 AM
magic5g's Avatar
If this is referred to me, amp is rated at 90x4 at 4 ohms, and my speakers are 75 rms. And sorry for hijacking your thread OP!
champppy
Mar 31, 2020 12:25 PM
Gip
Aug 24, 2015 05:31 PM
Frostbite91
Aug 2, 2015 04:59 PM
THMotorsports
Midwestern
Jul 22, 2015 10:27 AM
